Front end noise.
Hey all have 2002 f250 7.3 new problem just happened, font end growl in take off just in first gear. Slight noise while in neutral and park, front diff fluid and trans fluid new and correct level. Drive shafts, suspension, and brakes all checks out too. Thanks for help!
clutch fan problem? Not sure how to diagnose it, but thinking, with it not run'n, grab the fan and spin it. Any restriction?
I'll check the fan clutch. I can hear the noise in the flywheel area and trans temp went up to 150 today not normal for the truck. Started to slip in and out of gear with no power, also the od light on shifter started flashing. Ripping out trans this weekend will post when I complete thanks for help
Torque converter thanks for all your help!
