Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems
Old 08-26-2006, 05:31 PM
gwilliamson gwilliamson is offline
Send a message via MSN to gwilliamson
ticking ro knocking?????????? or torque converter
i was getting ready to pull my jeep to a wheeling trip and when i pulled into the driveway it sounded really rough... sounded like it was coming from the engine. but when i put it into gear, the noise when away for the most part...than when i actully drove forward or backward no noise execpt for idol in gear. it made the noise in park and nuetral. i just got this 99 f250 psd a week ago and they said when i got it the swaped a new 01 7.3 psd into it. could they have just not tightend down something or could it be like my mechanic said and a valve guide. or could it be something as simple as a loose wire.
Gwilliamson, ford psd newbie
Old 08-26-2006, 07:47 PM
00powerstrokin 00powerstrokin is offline
Moderator
Send a message via Yahoo to 00powerstrokin
what did the noise sound like? rattle? pinging?
Old 08-26-2006, 09:14 PM
it was a rattle for sure... very loud, sounded like it was gonna fall apart
Old 08-27-2006, 12:16 AM
Moderator
might be a cracked fly wheel or bearing. my dads truck was doing the same thing last week. we had to replace the flywheel and rebuld the transmission
Old 08-27-2006, 02:24 AM
you mean flex plate? i don't think autos have flywheels....the jeep has a flexplate in place of what the manual flexplate
Old 08-27-2006, 07:43 AM
mschn99 mschn99 is offline
honestly buddy the way you discribe it, it doubt its a cracked flexplate because that should get worse in gear. Im thinking your right on about the torque converter. Ive heard this before and while not being there i cant tell you for certantly, my "hunch" says thats gonna be it....
Old 08-27-2006, 11:01 AM
oh i was just clearing the confusion of flywheel and flexplate, but yes marc, as you are always on the ball, i bet it is also
Old 11-03-2006, 01:42 PM
it was the flex plate cracked all the way around the crank flange.
sorry i didn't post results earlier... and the next thing you know my t conver. went out along with the tranny blowing a front seal. i swaped in a reman and new torq conv. and all problems went away for about a week untill the new flexplate was cracked, it is in the shop right now cuz i'm sick of pulling trannys... i guess for put in a new motor before i bought it. so i think something is tweeked.
Old 11-08-2006, 09:19 AM
djsdiesel djsdiesel is offline
Powerstroke Techie
ford has a tsb about cracked fleaxplates
12944
1994-1999 F-SERIES SUPER DUTY/E-SERIES - ENHANCEMENT TO FLEX PLATE CRACK SOME 1994.5 - 1999 F-SERIES AND 1995-1999 ECONOLINE EQUIPPED WITH 7.3L DIT DIESEL ENGINE MAY DEVELOP A CRACKED FLEXPLATE. FOR FLEXPLATE REPLACEMENT ON 7.3L DIT DIESEL ENGINES (ALL 1994.5 - 1999 AUTOMATIC TRANSMISSION), PLEASE BE SURE TO PERFORM THE FOLLOWING INSPECTION WHEN SERVICING: 1. INSPECT THE FLYWHEEL REINFORCEMENT PLATE FOR DAMAGE. THE PLATE SHOULD BE FLAT AND FREE OF ANY GALLING. REPLACE IF DAMAGED (F4TZ-6A366-A). . 2. INSPECT THE CRANKCASE SPACER FOR DAMAGE. THE SPACER SHOULD BE FLAT AND FREE OF ANY GALLING. REPLACE IF DAMAGED (F81Z-6A366-AA). . 3. REPLACE THE ENGINE SPACER (F4TZ-6A369-A).
Old 11-09-2006, 05:04 PM
12944
this is what is was, in addition to 2 missing studs on the adapter plate coming off the block, the tranny was twisting and the crankshaft block was galled out from the first flexplate that great bear ford put on, when this second flexplate was wrecked i took it to a transmission shop and he went through it with me. so if you crack a flex plate, make sure that plate is not galled out and the studs are in place.
