Bad Injector? - Ford Powerstroke Diesel Forum
Old 02-25-2013, 05:25 AM
Bad Injector?
Ok, guys, it's been a while since I've posted on here, but I finally had my truck looked at by an actual Ford diesel mechanic. I put on a new oil filter, and did my own oil change (Rotella 15w40), we started it up with it hooked up to his computer, and noticed that it was burning a decent amount of oil. At that same time, a misfire or something showed up in cylinder number 5. So, he was thinking that it could be a bad o-ring, bad injector, or in the worse case scenario, a hole somewhere causing the oil to leak into the fuel system? I got ahold of another mechanic who said that he was pretty positive that it was a bad injector on cylinder 5. Have any of you guys ever had this problem, and what were the symptoms you had? It's causing mine to have a delay in the start/hard start depending on temperatures outside. Do you guys think I should just go ahead and buy a new injector, and have it put in, or should I sell the truck? I'd love to get it fixed up, because it's a 99 and has a lot of potential. If you need more info just go ahead and ask me.
Old 02-25-2013, 07:32 AM
how many miles are on the truck? injector o ring failure is something that does happen on these trucks. i would just try and fix it if it was me, if you dump it and buy something else you could just end up with someone elses headache.
Old 02-25-2013, 07:55 AM
The truck has 250k miles, but the motor only has 40k. I can't decide what I want to do with it. Is burning oil a symptom of a bad injector or injector o-ring?
Old 02-25-2013, 08:05 AM
thats pretty low miles for a 7.3 it could have sat around long enough to let the rubber o rings get brittle. if you have a bad o ring, oil can leak into the fuel which makes it hard to detect.
Old 02-25-2013, 08:11 AM
That's what I was told. Just not sure if I can pinpoint it without taking it to a dealer or mechanic.
Old 02-25-2013, 08:59 AM
If it is dumping enough oil I think you can start to see it in the fuel filter bowl, maybe take some out and put it in a glass jar so you can see it good. If it has a dark color there could be oil in it. I'm just grasping at straws here, I'm no expert. Hopefully someone with first hand experience will chime in.
Old 02-25-2013, 09:14 AM
I hope so, too. Thank you, though.
