Low fuel Pressure help?? - Ford Powerstroke Diesel Forum
post #1 of 15 Old 02-24-2013, 07:51 AM Thread Starter
justinlogue5_0's Avatar
I haven't noticed any running issues but my fuel pressure is a lot lower than every one recomends especially with my stage I's. I have done some reading on here and I have just confused my self. I tried the BB behind the spring (not sure if that is for our superdutys or the OBS) and just priming the pump brought it up to about 80 to 90 psi and blew out the filter o ring gasket so i took that back out. Do I need to get this blue spring I hear about? Its my E99 with a factory fuel pump and at idle I have 60 psi. Normal driving with moderate hills it holds 50 to 55psi and at WOT it will drop down to 40 to 45 psi. What do you all think? Thanks!
A little bit of this and a little bit of that. I want a lot more of this and a lot more of that
It never ends!
justinlogue5_0 is offline
post #2 of 15 Old 02-24-2013, 08:05 AM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
70 bucks is a heck of a lot cheaper than injectors. just my .02
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Smoked Lights, No Limit S2 Intake, 20% Tint, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED 6500K heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
post #3 of 15 Old 02-24-2013, 08:08 AM
timmyboy76's Avatar
or keep the BB in the FPR, and cut the spring..1/2 coil atta time ,til you achieve the psi you want.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #4 of 15 Old 02-24-2013, 08:09 AM Thread Starter
I missed something,what's 70 bucks? I obviously don't want to mess up my injectors.
It never ends!
post #5 of 15 Old 02-24-2013, 08:31 AM
timmyboy76's Avatar
we posted at same time..think the 70 buks is for a new FPR assy. Too high of f/p, will blow out the injector orings.
post #6 of 15 Old 02-24-2013, 10:42 AM Thread Starter
Think I will just order the blue spring everyone talks about and see what that brings it up to. Thanks.
It never ends!
post #7 of 15 Old 02-24-2013, 12:00 PM Thread Starter
Any one know the part number for this blue spring kit for my 7.3? All I can find is the kit for the 6.0's.
It never ends!
post #8 of 15 Old 02-24-2013, 12:06 PM
timmyboy76's Avatar
looks like, if someone wants to forfeit up a spring since they have the kit, otherwise, your only option is this route...
Riffraff Diesel: Fuel Rail Crossover™
FWIW, i have a BB in the fpr, and holds 70psi, 68 at wot, has about 2 full coils cut off too.
post #9 of 15 Old 02-24-2013, 12:20 PM Thread Starter
Oh I see now. We DO use the 6.0 spring on our 7.3 and I guess just throw the other pieces on a shelf some where. Well I think I will try what you did with the bb first and if i mess it up I will just order the blue spring kit. Thanks again for the help. I will post back with my results afterwards.
It never ends!
post #10 of 15 Old 02-24-2013, 12:23 PM
timmyboy76's Avatar
when doing so, with the "high" marks on the plunger, i wet-sanded them, 1000grit, to make smooth again...ya, its a pain, but after a few install/removals,...it becomes a quick tweeking of fpr. Just cut 1/2 coil atta time.
