Brakes HELP!
I just got my 2000 F250 and it started making a whirring noise whenever I hit the brake or even when I am stopped and an intersection waiting to go. What could it be any help would be greatly appreciated
Thanks, Kevin |
could be your pump.... do you feel any pedal vibration? have you made sure you have enough brake fluid in the res.?
Thanks
ya I do feel a vibration I feel like a dumbass for not checking the fluid I will go do that thanks for the help. Keep it coming guy ill update when I get back from outside lol
Thanks, Kevin |
Not Fluid
Fluid is full so that is not it but thanks
is it more of a squeaking noise like it could be your brakes or rotors? does it only happen when your trying sot stop or when your at a stop light as well just holding down the brake pedal?
Both
It happens at both times which makes it hard to figure out whats causing it...
Thanks, Kevin |
caliper could be hung up too i think
hey
Keep the suggestions coming!!
Thanks Kevin |
i have a brake problem too maybe u guys will be able to giv me some suggestions too. if u would look onfront page its called popping noise?
Check fluid in power steering pump. I had low fluid and it made the whirring noise so maybe that is your problem.
