bad MPG's after useing Diesel Kleen, anyone else? - Ford Powerstroke Diesel Forum
Old 12-21-2007, 01:13 PM
The last few tanks I have run have had crappy mileage, the only reason I can come up with is because I recently used the Power service Diesel Kleen. Any other things you might guess would cause this?
Old 12-21-2007, 01:15 PM
Desert Shield/Storm Vet
How bad of a decrease in mileage? Have you changed the way you drive?
Old 12-21-2007, 01:17 PM
well I normaly get around 325 miles pre 25gal tank, but now its seems like I get around 200. I just filled up and I only got around 35 miles on a 1/4 tank.
useing this stuff... http://www.clubafaceri.ro/files/clie...t18252_big.jpg
Old 12-21-2007, 01:18 PM
Ouch! When is the last time you changed your fuel filter? Any fuel leaks or extended idle times?
Old 12-21-2007, 01:23 PM
I use this product but the white bottle and I have not seen any change. Use it in both my trucks.
Old 12-21-2007, 01:34 PM
Big Daddy!
I just used the white bottle of Deisel Kleen, and didn't not see that. I did however recently read that the biggest robber of mileage is under inflated tires! Just food for thought?!
Old 12-21-2007, 02:09 PM
I just got the truck a few months ago, Have not changed the fuel filter, and its does idle for around 10-15 min in the morning sometimes. I guess the idle might do it. Do you think the fuel filter might do it? thanks!
Old 12-21-2007, 02:13 PM
Like Robert said, tire inflation or could be winter blend fuel. Where do you live?
Old 12-21-2007, 02:16 PM
try changing your fuel filter and see what happens.
Old 12-21-2007, 02:34 PM
diesel kleen is the best, I use a fuel bottle in every tank, its supposed to treat 100 so 35 just makes it better, runs smooth, good milliage, easy starts.
