2000 f250 died wont start - Ford Powerstroke Diesel Forum
Old 12-20-2007, 03:37 PM
2000 f250 with 11100 miles,quit on the highway like someone turned the key off.. will not start up..
well guys, ive read alot of post on hear and its all been helpfull. ive done all the most comon things like change the cps and unplug the icm.also checked in the fuel filter to see if it was pumping and it was.its not smoking out the exhaust. i dont no if their is fuel relay or not. i havent had the codes yet. this truck has never failed me... thanks for you help
Old 12-20-2007, 03:44 PM
BIG TRUCK, SMALL DRIVER
If the pump is pumping, it's not the relay. You may want to check the fuel pressure. Also see if you can get some codes pulled.
Welcome to the ORG.!
Old 12-20-2007, 03:46 PM
Check to see if the fuel bowl heater fuse is blown, does the wait to start light come on?
Old 12-20-2007, 04:56 PM
the wait to start light does come on and you can hear it click,also i checked the oil level its good.i no its hard with out the codes but im trying to check everything that i can do before i tow it in.
Old 12-20-2007, 05:02 PM
i also checked all the fuses under the dash
Old 12-20-2007, 06:02 PM
Are you sure the CPS you installed is a good one and you have a good connection at the plug? Don't forget, Ford has a recall on the CPS and is trading out the black one for a different model, gray I think.
Old 12-21-2007, 03:48 AM
i got mine at the ford dealer,and im showing a little tack movement. it was the gray one. also
Old 12-21-2007, 04:18 AM
ADMIN AND TECH
need to run a fuel pressure test and get codes pulled
Old 01-08-2008, 06:52 PM
got it running,replaced idm. but now it has no power and will barley go 60 mph. idles rough also..ant thouhts..
