99 PSD Overheat - Ford Powerstroke Diesel Forum
post #1 of 3 Old 12-16-2007, 09:31 AM Thread Starter
99 PSD Overheat
Have a 99 PSD that is experiencing an overheat issue. Recently replaced Thermostat, Water Pump, Radiator, and fan clutch. Dealer stated that an injector issue might be causing the overheat. Not having any smoke issues. Possibly a periodic miss at idle. Discovered this morning fuel leaking at the drain valve on the fuel bowl. Going to replace O-rings to make sure that the small loss in fuel isn't robbing fuel pressure and cause injector mishap. Looking for any other thoughts. I fear a cooling jacket may be clogged.
capt5215 is offline
post #2 of 3 Old 12-18-2007, 03:03 AM
Powerstroke Junkie
NCHornet's Avatar
Have you verified engine coolant temp? The reason I ask is a true over heating problem on the PSD is very rare, 98% of the time it is a faulty coolant sensor, or a bad gauge.
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #3 of 3 Old 12-18-2007, 03:18 AM
ADMIN AND TECH
SCUFFY828's Avatar
dont see it being a injector issue , like said before , very seldom does a 7.3 overheat , im sure you need to fix your fuel leak, but that doesnt cause any concerns either , definitly would check the gauge or sending unit
ITS STOCK
SCUFFY828 is offline
