Very weird and unpredictable problem HELP Please - Ford Powerstroke Diesel Forum
post #1 of 11 Old 12-15-2007, 06:52 PM Thread Starter
Hey guys ive read through a lot of the forum and i cant seem to duplicate my problem anywhere.Anyways about 2 weeks ago i got in my 2000 f350 psd and started it up fine on first try with outside temp around 30deg.I went out he road about half a mile and the truck felt like it was running out of fuel no throttle and whit smoke coming out the back.I let off the throttle and coasted for a bit and got back in the throttle and it went on its merry way with no problems.It done this same thing the next day at the exact same spot on the road and then was fine again.Well this week i drove it everyday and it was very warm here this week (mid 70s) and it never done it once.Then today 35 deg and at the exact same spot down the road here it goes again,then corrects and runs fine.What gives?
thanks in advance
Jason
PS on a side note im looking for some one who can make me an intake pipe for a cool air system,ive got the filter and clamps but i need a pipe.
budracer1 is offline
post #2 of 11 Old 12-17-2007, 10:52 AM
I just posted something very similar to yours (2000 PSD; hard to start, white smoke; more) before I read this. Sounds like the same problem, but yours is in the beginning stages. Maybe we'll both get answers soon.
Elton
Birmingham, Alabama
Lone_Ranger is offline
post #3 of 11 Old 12-17-2007, 11:24 AM
Powerstroke Firefighter's Avatar
Same
I think our glow plugs arenot warming up enough?
Powerstroke Firefighter is offline
post #4 of 11 Old 12-17-2007, 06:21 PM Thread Starter
Well ive had a few people tell me to check glow plug relay but i have no problem starting it on one cycle,i may swith the glow plug relay wires over to the intake heater relay since im not using it and see if it helps.
post #5 of 11 Old 12-18-2007, 02:55 AM
Powerstroke Junkie
NCHornet's Avatar
This is simply your EBBV closing, it only happens when it is cold and should stop after the vehicle warms up. There is nothing wrong at all. If you are having problems starting you need to troubleshoot your GP system. I have a sticky in the maintenance section that tells you how.
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #6 of 11 Old 12-18-2007, 05:37 PM
Im having a weird problem with mine where ever since its been cold outside it makes this loud slushing noise coming from the engine compartment and the truck bogs down. it will only last a few seconds but does it every couple seconds or sometimes minutes until up to operating temp.. any ideas?
My Garage:
2004 Ford F250 Super Duty- daily driver
2000 Ford F150 Lightning - garage queen
1991 Nissan 300ZX Twin Turbo- garage queen
1912 Ford Model T - garage queen
white99psd is offline
post #7 of 11 Old 12-18-2007, 05:45 PM
Powerstroke Techie
alabamafrog's Avatar
As NCHornet said, sound like EBPV (exhaust back pressure valve) easy to test by unplugging the connector under the turbo, this will disable it electrically and allow you to see if it makes any difference.
“Government, even in its best state, is but a necessary evil; in its worst state, an intolerable one” (T Paine)
Government cannot give anyone anything without stealing it from someone else. (A Frog)
alabamafrog is offline
post #8 of 11 Old 12-18-2007, 07:00 PM
SMKSTAX's Avatar
Definitely the EBPV. The wooshing sound and loss of power are the tell tale signs.
RICK
97 F350 CREW CAB 4x4, 7.3 TURBO DIESEL, DIY INTAKE , TW TUNES
GRAND ROCK POWERFLOW STACK KIT W/5" MITRES
3.55 REARS, 3" DOWNPIPE, FPR SHIMMED WITH GAUGE
SMKSTAX is offline
post #9 of 11 Old 12-19-2007, 02:52 AM
Powerstroke Junkie
NCHornet's Avatar
You can always tell when it's winter time by the posts that appear on the forums, lol!!!
NCH
Ford AIS/ BTM, FTVB
KMC Wheels x 4
NCHornet is offline
post #10 of 11 Old 12-19-2007, 01:54 PM Thread Starter
so the ebpv is something that can just go bad like a cps?Cause this is the first winter it has ever done this.Thanks for your help guys.
Jason
