block heater now working all the time?? and FASS? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 12-14-2007, 01:31 AM Thread Starter
chrispaine's Avatar
block heater not working all the time?? and FASS?
I am in Michigan and it gets cold here once in awhile so I put my 7.3 block heater on a timer and it was working great water gage was almost on normal operating temps when I went to drive it. When I would unplug it from the cord I would see a arc/spark (what ever you want to call it) but the truck would be warm. For some reason half the time now I donít get the arc and the truck is cold as if the heater is just not working. Now I know I have power to the end of the cord since the cords end has a little light in it to tell you it has power. What could that be? a fuse? would think it was a fuse because sometimes it works some times it doesnít. I took a look at the end of the plug (trucks end) and I donít see any cuts/shorts.
Also does anyone run a FASS system in your truck? I'm thinking about getting one. Thanks !
2000 F250 7.3L EX.Cab Short Bed -05 Front end w/ HID's - Leveling shackles - Wicked wheel - Dipricol gauges - FORD AIS intake - Foil Delete - LINE-X Rockers - CCV dump - 315/70/17 BFG A/T with Eagle Alloy 197's - ELC w/ coolant filter and around the belt hose - PHP Hydra - Hpress oil x
On the way--
-Fusion front bumper - ATS 3" fender flares
chrispaine is offline
post #2 of 6 Old 12-14-2007, 02:13 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
The end on the block heater cord may be bad
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #3 of 6 Old 12-14-2007, 12:49 PM Thread Starter
chrispaine's Avatar
thats what I was thinking, but I wiggle it around and it didn't help. werid, I'll replace the end and see if that helps. maybe its just all corroded inside or something.
On the way--
post #4 of 6 Old 12-14-2007, 12:51 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
you can get the replacement cord at Napa for about 20 bucks also
Email:
Edge Insight CTS
Coolant filter
Dave is offline
post #5 of 6 Old 12-14-2007, 12:57 PM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 30 Post(s)
Your truck gets to normal temp just being plugged in...in Michigan no less?
Mine barely gets a little above the cold line. The commander shows water temp around 110-120 depending on outside temps. but no where near 180.
2003 6.0 F350 dually on high cholesterol fuel (WVO)
2000 7.3 Excursion also on a high cholesterol fuel
Clay Henry is offline
post #6 of 6 Old 12-14-2007, 01:44 PM Thread Starter
chrispaine's Avatar
sorry not normal running temp, it would get near the first line in the factory gage. but thatís when the ambient temps are above freezing. but is still moves the gage quite a bit when its below freezing.
On the way--
