oil in intercooler pipes - Ford Powerstroke Diesel Forum
Old 12-11-2007, 02:15 PM
zac zac is offline
i have a 99 7.3 and started to notice that the boots on my intercooler pipes have become oily. have havent started looking but my my first thought is that the turbo might be leaking. has this happened to anyone before?
Old 12-11-2007, 02:30 PM
Almostdunfukinwidit
A little oil in there is normal. That is where the CCV vents to. The CCV mod prevents that.
Old 12-11-2007, 02:51 PM
no that you say that my boots are oily also... jsut never thoguht anything of it so this is normal you say?
Old 12-11-2007, 03:09 PM
Location: Quit Iraq, got a house in Tooele, Ut, Back in a big wrecker playing in traffic!
more or less. the crankcase vent is connected to the intake before the turbo. there is a slight vacuum, plus the little bit of crankcase pressure from blowby inside the engine, that draws the vapors in, as they travel through the tubes through the charge air, they are heavier than the air, so they settle. they will show up as oily residue around all the joints in the pressurized parts of the intake system.
do a search for the CCV Mod, there is an easy and inexpensive way to reroute the vent hoses to prevent it.
Old 12-11-2007, 03:10 PM
is there any reason 2 do this mod performance wise? or any reason really?
Old 12-11-2007, 06:11 PM
Almostdunfukinwidit
other than to stop the oily boots tubes and intercooler no real reason
Old 12-17-2007, 01:40 PM
zac zac is offline
thanks for the replys!
Old 12-18-2007, 02:52 AM
Powerstroke Junkie
I sent y'all some info on the CCV mod I manufacture, it is one of the best non performance mods you can do to your truck and it will completely stop the oily intake mess Ferd created !! PM me with any ?
NCH
Old 12-18-2007, 05:12 AM
ZAC
If you install a crankcase vent kit be careful how you run the line. If you have low spots the moisture will collect in the low spot and freeze if you drive in cold weather. This will create backpressure and push oil out of the engine. In my case (I live in Minnesota) the oil was pushed out of the turbo. Made a real mess. The solution was to shorten the line and make sure there were no low spots. I posted the problem as crankcase vent problem if you would like to read that thread.
Old 12-18-2007, 04:27 PM
zac zac is offline
Thanks again!
