Heavy Heavy White smoke, and diesel smell.... - Ford Powerstroke Diesel Forum
Old 02-08-2013, 04:58 PM
Please help,,,,
Truck was running rough, started blowing white smoke.
I brought it home and did and oil change to see if there was any signs in the oil..
I also had been having an oil leak from the one of the oil lines that feed the fuel pump, so I fixed those with new o-rings.
I did find a fuel leak from the fitting on top of the fuel bowl on the drivers side, the one with the spring in it (pressure regulator??)
Any body have any ideas of what is the problem?
After changing the oil, cleaning all the intake boots and putting everything back together I took it for a road test..
Motor was loud, a little shacky, and I heard a ton of noise from the turbo (like excessive blow off sound).
Went around the block and back to my shop... still tons of smoke and heavy diesel smell????
WHAT THE F______?
Old 02-10-2013, 02:34 PM
with the leak at the FPR (fuel pressure regulator), i'm thinking your seeing excessive fuel psi, and blew an oring/s out, around the injectors...again just a thought.
Also, its possible that the turbo seals are gone. Creating the smoke since oils' bypassing its circuit and being blown out/burnt, through the exhaust...
Remove the fuel bowl filter and see if the fiilter is oil contaminated.
Old 02-10-2013, 05:06 PM
Thanks, I need to now find the time and money to tear into this thing and find out!!
I will try and keep posted on this subject to help out!!
Old 02-10-2013, 08:54 PM
50925K172
hit up a Harbor Freight, pick up an el-cheapo manual gauge to read above 100psi. Then get a flexible grease gun hose to attach gauge to..(need 1/8in npt threads). Hit up McMaster-Carr and order one of these. Its the adaptor to fit correctly into the ports, on backside of fuel bowl, to read psi. Pass side port is "post" filter.
McMaster-Carr
OR, get a mechanical psi gauge and a barb fitting that can thread onto it, hopefully a 3/8in barb, get some fuel line, and attach it to the drain spout, that runs from the fuel bowl to under the truck. Open up the drainvalve, attach hose to it, then turn truck to "acc". Get ur psi reading from there.
