Truck stumbles while trying to accelerating - Ford Powerstroke Diesel Forum
post #1 of 9 Old 02-08-2013, 08:22 AM Thread Starter
What is going is that this truck starts to what I call stumble if while your driving
if you decide to punch the pedal to floor while driving or it just does it when it feels like it.It does run a bit better when eng is hotter but still does it.I was thinking could it be eot sensor but their is code for injector drive module...
2000 7.3 powerstroke 5 speed 2wd. Fuel psi holding at 55 at idle and 75 while
driving.Deadhead hpop pump 2800 psi,dropped fuel tank no mixing of oil and engine isn't making fuel don;t think it is injector o rings.Unplugged icp pressure,still no difference.Oil is fresh
along with fuel filter and fuel is clean and pure...not sure if trying a eot sensor or replacing injector drive module need help thnaks
chubacabra is offline
post #2 of 9 Old 02-08-2013, 03:25 PM Thread Starter
deleted codes driven it over 100 miles code for injector drive gone...no codes still stumbling
post #3 of 9 Old 02-13-2013, 06:13 PM Thread Starter
Anyone have any advice???
post #4 of 9 Old 02-17-2013, 05:42 PM
I dealt w something like that for a while. Truck had to be running for like 15/20 min n warm before the truck would actually go anywhere. it would idle its way around but when i put the pedal to the floor nothing would happen. Found out that it was my oil levels. Have you checked your oil level? Mine was SUPER low!! Needed an oil change anyway. So, now that i have changed my oil and have it at the proper level its back to normal
JMalmy21..00/7.3 is offline
post #5 of 9 Old 02-18-2013, 04:38 AM
Powerstroke Junkie
NCHornet's Avatar
check your uvc harness connections, you are explaing tried and true symptoms of loose or burnt connections.
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #6 of 9 Old 02-18-2013, 05:30 AM
The Maddawg
maddawg89's Avatar
Quoted: 290 Post(s)
Feedback Score: 3 reviews
Mine kinda does the same. It lags for about 3 seconds and then goes. When it goes it goes, but it's annoying when your trying to pull out somewhere and it lags..... Tps?
2005 F250 6.0 Powerhouse Lariat
Bully GT Platinum with Quick Tricks
Bully Dog intake
Everything else stock.
Moto Metal 18in rims wrapped in 275/70 Mud Claw Extremes
2003 F250 cclb flat bed.
All stock 7.3 turtle
maddawg89 is offline
post #7 of 9 Old 03-02-2013, 10:30 AM
Eco Taxi's Avatar
Possible clog in the pick up screen inside the fuel tank, I've read where that internal screen causes problems like that
Kyle
2001 F350 Chassis Cab 4x4 DRW Flatbed 130k miles+
Quad Gauge Pillar - Aeroforce Interceptor & Glowshift Series 7 EGT, Boost, Trans Temp
Foil Delete | Marinco Mod | High Torque 4kw Starter | Door Seal Mod | AIH Delete | Coolant Filter & 203* Thermostat w/ Billet Aluminum Housing | Hutch Mod | RiffRaff Fpx, Hpx, boots | WW2 | Deleted ebpv
“The good thing about science is that it's true whether or not you believe in it.” ― Neil deGrasse Tyson
Eco Taxi is offline
post #8 of 9 Old 03-02-2013, 11:09 AM
Powerstroke Techie
Quoted: 414 Post(s)
run an injector buzz test. you're throwing an idm code. clearly, there is something the matter with at least one injector circuit which includes the idm as well.
just so you know, codes will clear from memory on their own. usually within 40-80 warm up cycles. so you know, if you still have a code memory, and nothing was done to attempt a repair, most likely the problem still resides.
the richest ones are not those who have the most, but those who need the least
**i don't use capitals. deal with it**
kaya is online now
post #9 of 9 Old 03-02-2013, 11:09 AM
The Maddawg
maddawg89's Avatar
Quoted: 290 Post(s)
I removed those and mine still does it.....
Bully Dog intake
