electrical issue in a 2002 f250 - Ford Powerstroke Diesel Forum
post #1 of 7 Old 02-05-2013, 08:18 PM Thread Starter
I'm tryin to help a guy out and fix the starting problems on his sons psd. after work on the side. I have no books on this unit at all and the 2002 seems to be it's own breed of cat.
I have found the grounds at the three pins at the pcm go open with the key on.Is this normal? last i knew a ground wire was grounded at all times. This is g101 in wich i am referring to. the pcm was bad-had a burnt transister in it. 4wd module was burnt also.
as a side note, the dome lamps dont work either.
originally thought there was a problem with the glow plug system but the pcm is not activating the glow plug relay. i have printed a lot of material from ford, but there is no symptom code for this concern that i can find.
The idm relay also buzzes continuously with the key in the key in the on position.
PLEASE guys, point me in the right direction.
dusty14319 is offline
post #2 of 7 Old 02-05-2013, 08:25 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Does the wait to start light come on?
dhanna6powerstroke is offline
post #3 of 7 Old 02-05-2013, 08:27 PM Thread Starter
glow plug light stays on continuously.
post #4 of 7 Old 02-05-2013, 08:31 PM
Mod Newbie
Quoted: 20 Post(s)
That is different. I don't have any idea on that one.
post #5 of 7 Old 02-06-2013, 07:40 AM
Quoted: 176 Post(s)
Feedback Score: 3 reviews
When my '02 had the "buzzing IDM relay" it was a connector HERE-> POTENTIAL ELECTRICAL CORROSION if your truck is like mine......
NoRalPh is offline
post #6 of 7 Old 02-06-2013, 07:50 AM Thread Starter
already been there and it was fixed by someone else. i am more concerned about the ground issues at the pcm.
post #7 of 7 Old 02-08-2013, 04:27 PM Thread Starter
G101 was not connected properly.
