AIR PROBLEM MAYBE - Ford Powerstroke Diesel Forum
View Poll Results: This is a good thread most don't have guts to ask
filter problem 3 100.00%
Starting Fluid 0 0%
Voters: 3. You may not vote on this poll
Old 12-04-2007, 09:14 AM
AIR PROBLEM MAYBE
After changing my Fuel Filter Housing the only way I could get it to start was spray a dab of Starter Fluid about 10 times then it kept running. since then in about 200 miles of driving I've had do the same only 1 or 2 squirts on 3 occasions.It's running fine now but was wondering if there was a way to clean your fuel system, like maybe a flush. The housing is seeping some fuel where it was welded but ran fine when it had a hole the size of a pencil.That makes me think that the seepage isn't causing this.
Old 12-04-2007, 09:31 AM
HELP
I could really use some help here please
Old 12-04-2007, 09:38 AM
Maybe this will help? That was the first time I ever changed my Fuel Filter since new. I Had a lot of problems trying to stay alive and just never thought to change it. 210k on truck now honest had crud in bottom of housing and never had a problem until I almost fixed the leal.
Old 12-04-2007, 09:45 AM
what year is the truck. I have read on here never use ether on a powersrtoke.Im no deisel expert by any means but possible injectors are gummed up from such a dirty filter?
Old 12-04-2007, 09:49 AM
You put 210k on the original fuel filter?
Old 12-04-2007, 09:50 AM
Air
97 that was the only thing I new to start it . I thought I read that too
Old 12-04-2007, 09:57 AM
KVFD
I will tell you why not to use either on any diesel or gas burner only on the bigger engines and all it takes is a whisper. Either is such a hot dry start on engines it is hard on gaskets and if you use to much you will blow the aluminum heads right off them puppies. i have used a little on my 84 chevy 6.2 litre. but i wouldnt do it on my powerstroke
Old 12-04-2007, 10:00 AM
Think how much I saved $$
How would you get it to start
Old 12-04-2007, 10:35 AM
210k first filter change
BUMP UP PLEASE
Old 12-04-2007, 10:56 AM
Cool NOTHING WAS WRONG
IT RAN PERFECT BEFORE
