Fuel Gauge - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-28-2007, 10:28 AM Thread Starter
Berm Buster
Speedyboy487's Avatar
Fuel Gauge
My fuel gauge is acting up. When i start my truck it will read the proper tank level. But within about 2 minutes of me driving it will go to the empty position and the fuel light will come on. If i start the truck and let it idle the gauge will read correct. I let the truck idle for 20 mins and the gauge was fine. Any ideas And the last 4 times i fueled up i let the truck run while fueling. could that be it.
Speedyboy487 is offline
post #2 of 7 Old 11-28-2007, 10:37 AM
duct tape & zip ties
bigcountrysg's Avatar
The problem is the fuel tank level sending unit. I just repaired mine. What I found is you should really shut the truck off when you fill up. This will prolong the life of the fuel tank level sending unit. If you do not shut off the truck. The float will rise but the gauge will not be correct until you shut the truck off and turn it back on.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #3 of 7 Old 11-28-2007, 10:44 AM Thread Starter
Berm Buster
How did you fix yours. drop the tank or take the bed off. What was the damage on the wallet.
2002 F-250 7.3L 4x4,6 Speed,Hyperpac, MBRP 4”dp5” K&N/DIY Intake, Foil Delete, Rough Country leveling kit, 305/70/16 Dunlop Mud Rover
Autometer Ultra Lite ll Pyro Boost- TW tunes
post #4 of 7 Old 11-28-2007, 10:52 AM
I dropped the tank that took about 15 minutes, then I removed the fuel sending assmblely that took about 5 more minutes. Then I went to the local junkyard and found a whole tank with pick up tube assemblely for 150. Brought it to my house hooked up the wiring tested out the fuel tank level sending unit to make sure it worked. Then I reassembled everything. Total time I would say 45 minutes for the repair. Not including the going for parts. Total cost to me was 150 at the local junk yard. But now I have a spare tank laying around the house. The dealership price is 350 for the fuel tank level sending unit.
2002 7.3L burnt
post #5 of 7 Old 11-28-2007, 12:14 PM Thread Starter
Berm Buster
The fuel pump is seperate from the sending unit right. Just wanted to double check
post #6 of 7 Old 11-28-2007, 12:16 PM
Yes the fuel pump is on the frame rail on the driverside of the truck.
2002 7.3L burnt
post #7 of 7 Old 11-28-2007, 05:04 PM
Powerstroke Techie
alabamafrog's Avatar
If you have the tank down anyway that is a great time to do the tank and prepump filter mods, costs around $30 for all the parts and is well worth it, made a huge difference in how my truck sounds and protects me against getting bad loads of fuel and adds about 7 gallons to my tank capacity and I can now fill it up without any backsplash. Check out my fuel system pictures to see what I’m talking about.
“Government, even in its best state, is but a necessary evil; in its worst state, an intolerable one” (T Paine)
Government cannot give anyone anything without stealing it from someone else. (A Frog)
alabamafrog is offline
