no wts light
Hello I searched the forums looking for help but Don't think anyone else has had the same issue as myself. I do have a dp tuner and its plugged in tightly to the pcm I have checked that. I was having alternator trouble the alternator repair man said it was the pcm I didn't believe him. Now I'll turn the key and no Wait to Start light comes on, but if i try again immediately it'll come right on. So I'm thinking its the pcm. Unless someone else has something else to check. I forgot but were on the pcm is the pcm code so I can call and get a new one does anyone have an idea besides ford were to buy one at?
Thanks, Clint |
The "No WTS" is, usually, a good indication that the PCM isn't running. If it comes back every time you recycle the key then, I donno,,, I would start by removing (completely) the Tuner from the PCM.
Will it start if the WTS didn't illuminate? Maybe we're over thinking this... ![]() You can read the PCM code form under the hood (with a mirror) by looking at the fender-side of the connector on the firewall. |
No I didn't try that but I will if the wts light doesn't come on. Thank you
When you dont get a wait to start light, do u still hear your fuel pump??? If not its most likely pcm bad. I just had to replace mine. I found a company that repairs them and flashes them so they are ready to be installed when recieved. Its Rogue Motors.
