Turbo rebuild - Ford Powerstroke Diesel Forum
Old 01-25-2013, 04:56 AM
Turbo rebuild
Are there any tricks to separate the exhaust housing from the center section? It's seized up. I used a rubber mallet and a big screwdriver through the pedestal bolt holes. I even used PB Blaster. I ain't budged yet. Turbo rebuild-imageuploadedbyag-free1359122124.326504.jpg
Old 01-25-2013, 06:40 AM
stupid ?, but have you removed the 4-bolts, securing it to housing? If so, i think i used a flathead to pry ever so lightly in a circular pattern, for it to pop then.
Old 01-25-2013, 07:06 AM
Turbo rebuild
The bolts are out. I've used prybars but ill try again.
Old 01-25-2013, 07:11 AM
Turbo rebuild
Yah I got it.
Old 01-25-2013, 07:41 AM
cool....good luck.
Old 01-25-2013, 07:53 AM
Turbo rebuild
The cup shield under the exhaust turbine, do I need to take that off for rebuild?
Old 01-25-2013, 08:02 AM
you wanna remove it to clean all the soot.
Old 01-25-2013, 08:03 AM
Welcome to BDrummonds Van Turbo Rebuild Web Page
Old 01-25-2013, 08:11 AM
Turbo rebuild
What's the best way to get it off?
Old 01-25-2013, 10:20 AM
Premium Starfish Member
Unless it's cracked - no reason to take that heat shield off.
Then to get it off - usually the best way to do it will be to apply some heat then pry it off (carefully)
That BDrummonds build is a good starting point - if you need some additional pics, I have a step by step pic walk-through of my rebuild if you need it.
