Any ideas as to where this fuel is leaking from?? - Ford Powerstroke Diesel Forum
Old 01-24-2013, 03:46 PM
I've noticed a considerable amount of diesel on the garage floor lately.. At least about a 8-12 inch diameter circle here are some pictures please chime if you can lead me into the right direction
Old 01-24-2013, 03:47 PM
More pictures
Old 01-24-2013, 05:24 PM
Most common is the fuel bowl... Can't tell to good.
Old 01-25-2013, 06:45 AM
crawl atop the motor, and look down inside the valley. Try wiping everything up , then fire motor. See where the leak is. Maybe fuel bowl or the p/s fuel line would be my guess
Old 01-25-2013, 06:46 AM
yea especially check the water/fuel drain valve. most time the o rings go bad and draw up. you can replace them with the viton o rings.
