Truck is surging and dying - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-19-2007, 07:13 AM Thread Starter
I have a 2001, F-250, 7.3L. It all started a couple months ago with the engine surging once and awhile at highway speeds. It progressively has gotten worse. I've changed the cam sensor, had a mechanic look at it, and still can't figure out what is wrong. Now, it's just dying while idling. I have the bullydog tuner, and I've de-programmed that, and still having problems. Other than the surging and dying while idling, the truck has been running good. Any thoughts or ideas would be greatly appreciated.
Thanks, Craig
gcm4255 is offline
post #2 of 6 Old 11-19-2007, 07:30 AM
Navy Beer Guzzler
Mikesf250's Avatar
Mine had that problem I had put too much Lucas Oil Stabilizer in the oil you might just try oil change its cheap and might fix it.
Dodge is for people to lazy put a Cummins in a real truck
2001 F250 7.3L 4x4 = 4" Lift/ 35"Pro Comp Tires/ 16x10 Pro Comp Wheels/ Air Raid Intake/ Turbo back 4" dual stainless exhaust/ Map Fooler/ ZOODAD Mod/ SCT Xcal2/ Quadzilla Commander.
Mikesf250 is offline
post #3 of 6 Old 11-19-2007, 07:46 AM
is this truck running any codes?
mechanic@ivfire.com is offline
post #4 of 6 Old 11-19-2007, 07:48 AM
might wanna to check the icp or ipr sensors
post #5 of 6 Old 11-19-2007, 07:54 AM
also might wanna check injector harness...but that will almost always throws codes..
...Is your lift pump leaking? does a 01 have a mechanical or electric lift pump?I don't know
because i have a 02 7.3 but work on 93-97 7.3s all day
post #6 of 6 Old 11-19-2007, 07:59 AM Thread Starter
It hasn't thrown out any codes.
gcm4255 is offline
