front axle problems, need help deciding brands - Ford Powerstroke Diesel Forum
Old 01-20-2013, 10:53 AM
Exclamation front axle problems, need help deciding brands
2000 F250, 4wd, Lock/auto lockouts,
Ok, so here's the deal, driving down the road about 20 mph and start hearing grinding noise on front passenger side. found out it is the needle bearings on the inside of the hub assembly. took it all apart, found out my seals are bad and letting water in and have destroyed my factory lockouts and also the bearing int he hub assembly is going bad . soooooo, looking at new hub assemblys and new lockouts. Here's my questions
1. Not trying to break the bank (LCpl budget here) where would be the best deal to get both new hub assembly's?
2. What ABS setup do i need?(front/rear/4wheel)
3. Do i need a conversion kit to go from Lock/Auto lockouts to manual lockouts?
4. Is there a vaccum line that needs to be capped when i change from mine to manuals?
really trying to have parts here by next weekend so i can get it all done. Any help would be appreciated
Old 01-20-2013, 09:24 PM
Johnny Law Brown
Timken hub assemblies warn lock outs standard or premium and yes cap vacuum line i plugged mine at the frame unscrewed the port on the knuckle and replaced it with a grease zerk some it works to grease them. Some say it doesn't but what the hell it can't hurt
