please help me with my ford - Ford Powerstroke Diesel Forum
Old 11-16-2007, 05:19 AM
my truck starts up fine but will just shut down sometimes?? and when i try to start it back the wait to start lite will either flash really fast and then go off or flash one time realy fast and go off and it will not start. after a few mins of swithing it on off the light will stay on like it is suppose to do and then it will start? and I replaced this cam sesor about a year ago? thanks for any help.
Old 11-16-2007, 05:24 AM
duct tape & zip ties
What year truck is it.
Old 11-16-2007, 05:28 AM
srry about that it is a 1999 f350
Old 11-16-2007, 05:38 AM
Well does the truck eventually stay running like after so many starts. It sounds to me like a fuel supply problem. Because it is starting up and running for a few minutes then shuts down. The next time you start it up and it shuts down check the fuel filter housing to see if there is fuel in it. When it does start up and run how does it run.
Although it is possible that the Cam Position Sensor is failing. Have you scanned the truck for codes. If it is possible see if you can get that done. Even though your SES is not on. It is still possible to have trouble codes stored in the computer.
Old 11-16-2007, 05:43 AM
it runs good when it does start but like a said it will not start till the wait to start lite comes on like it should. and most of the time when it does this the ses lite wil stay on when the wait to start lite is flashing fast?? what is a good code reader to buy? and where? thanks for your help
Old 11-16-2007, 05:52 AM
Ok I am going to recant my earlier statement about a fuel supply problem. Take a volt meter. Check the voltage at the glowplug relays under the hood of the truck. They are located on the top of the engine towards the left side kinda like at 11 o'clock behind the fuel filter housing. I bet one of your glow plug relays are bad if not both of them. If your relay or relays are bad then that could cause your wait to start light to act the way it is.
As for a code scanner I have an Actron 9145. It works pretty good for our trucks.
Old 11-16-2007, 05:55 AM
I think i know where one is but not sure where the 2nd one is? will my truck have 2 relays?
Old 11-16-2007, 05:59 AM
Yes and they are right next to each other.
Old 11-16-2007, 06:04 AM
mine only has one then that is all i see???
Old 11-16-2007, 07:42 AM
Ok maybe the 99's only had one. My 2002 has two they sit right next to each other.
Check the relay and see if you have 12 volts on both big posts with the key on.
