FUEL CONSUMPTION - Ford Powerstroke Diesel Forum
post #1 of 23 Old 11-14-2007, 10:18 AM Thread Starter
Quadrunner's Avatar
FUEL CONSUMPTION
Okay so heres the deal. My truck was in the shop 2 weeks ago because of bad fuel. They (dealership) did 4 fuel system flushes and changed out the fuel filter each time. They said that they cleaned the fuel injectors. Before this happend the truck was getting close to 19-20 MPG of fuel. Now it is getting close to 9 MPG what could be the cause of this drastic change of the amount of fuel the truck is using?????
Quadrunner is offline
post #2 of 23 Old 11-14-2007, 10:25 AM
SMKSTAX's Avatar
What year is your truck? Did they clean the fuel regulator screen? Don't know if this directly relates to your problem.
RICK
97 F350 CREW CAB 4x4, 7.3 TURBO DIESEL, DIY INTAKE , TW TUNES
GRAND ROCK POWERFLOW STACK KIT W/5" MITRES
3.55 REARS, 3" DOWNPIPE, FPR SHIMMED WITH GAUGE
SMKSTAX is offline
post #3 of 23 Old 11-14-2007, 02:50 PM Thread Starter
Quadrunner's Avatar
The truck is a 99. Not sure if they cleaned the regulator screen or not. I am taking it back to them on Friday and they are going to change out the Fuel Filter again. They said that could be one of the reasons. They also said my driving habbits as well. But I do not let the truck get over 2,000 RPM while I am driving in the city. Could this be bad I dont think so but hey stranger things could happen. My thought is if I keep the RPM's lower I will save on fuel. $3.50 per gallon. OUCH!!!!
post #4 of 23 Old 11-14-2007, 02:53 PM
SMKSTAX's Avatar
Even with bad driving habits you should still be better than 9mpg's.
RICK
SMKSTAX is offline
post #5 of 23 Old 11-14-2007, 03:19 PM
Quoted: 2 Post(s)
Did your driving habits change before/after the fuel problem? I'd bet not, so that shouldn't be part of the equation.
02 F350 CC 7.3 PS, auto, 6x6, 4.10 gears LB. AFE stage 2 intake, 4" AFE SS exh, 6.0 atf cooler, DP tuner with five stages
Eng Temp gauge, EGT guage and Trans temp gauge. J.Woods valve body ATS turbo housing. Cooling sys filter & waterless coolant. NON WORKING POS FASS fuel filter sys. Brightbox headlites. I don't care what they say "There's no replacement for displacement."
Don't believe statements about anything being better than a 7.3
GOD BLESS AMERICA!!!!
Bart_3500 is offline
post #6 of 23 Old 11-14-2007, 07:10 PM Thread Starter
Quadrunner's Avatar
no the driving habbits have not changed at all. But could a dirty Fuel filter cause that much of a loss on the MPG
post #7 of 23 Old 11-15-2007, 05:59 AM
Stroken n Smoken's Avatar
Whats this fuel regulator screen? where is this located at? I need to change my fuel filter going into winter here and thought maybe I should check that too, mileage has been droping the last couple months, Thanks!
Doug
99.5 7.3 CC SB PSD
Bullydog 4 bank 6 pos. chip
Bullydog Shift Enhancer Kit
K&N Cold Air Intake
4 In MBRP Turbo Back Exhaust
Autometer 3 Gauge A Pillar Kit
Map Fooler
Wastegate Deleter
Stroken n Smoken is offline
post #8 of 23 Old 11-15-2007, 08:53 AM
Same thing with my truck, used to get 19-21MPG
Now i get 7-9 no matter what empty or loaded
Fuel filter and air filter are good
changed out a certain sensor, and it shot me back up to 22 MPG, but now a few months later its back to 9 MPG.
Any other sensors or ideas??
Its a 99 7.3
Afe stage 2 intake
chip
built trans
pillar pod w/ autometer gauges
smoke you is offline
post #9 of 23 Old 11-15-2007, 12:02 PM Thread Starter
Quadrunner's Avatar
What sensor did you change out???
post #10 of 23 Old 11-15-2007, 01:43 PM
Cynic
Dirk's Avatar
Echoing the screen question.
Best Car & Motorcycle Insurance | Auto/Moto Protection Today | FREE Trade-In Quote
Voluntary Banishment: Knowing when to leave.
Total Diesel Performance\Unlimited Diesel Performance\Diesel Innovations\BTS\Terminator Engineering\Swamp's Diesel Performance\Black Widow Diesel\Calvert Racing
Dirk is offline
