No Crank After Oil Change - Ford Powerstroke Diesel Forum
Old 01-15-2013, 07:16 AM
Started it up ran it for 10 minutes of so before oil change to warm up the oil, started and ran fine. Got everything changed put the key in to start it and nothing. WTS light comes on and so does the fuel pump but no power to the starter. I checked the hpop oil level and its good. Tried starting in neutral didnt change anything. Checked all fuses. I can hear the relay click under steering column when I turn the key all the way. Also checked the solenoid on the passenger side firewall and there is no power to the small wire with the key turned all the way. I can start it fine by crossing the posts on the same solenoid but nothing with the key! Anything else to check?? Any help is greatly appreciated!
