feels like i lost power - Ford Powerstroke Diesel Forum
Old 11-10-2007, 05:32 PM
hey guys i was playing with the settings on my chip tonight ,its always on 80econo. i turned to my 100 hp setting and nothing seemed to change no smoke no more power. it is a 4 pos ts chip with BTS tuning
any ideas as to what i could check
Old 11-11-2007, 05:07 AM
Old 11-11-2007, 05:27 AM
ADMIN AND TECH
are the rest of the positions making a change ?
Old 11-11-2007, 06:08 AM
i can see a difference in my 2 tow positions boost dont build as fast and the trans shifts different
Old 11-11-2007, 06:12 AM
how can i check the compression on this engine? this morning i went took my air intake tube off to look at the turbo and found some oil in the tube by the ccv hole, i have a little bit of blow by about the same as a steaming cup of coffee on a cold day
Old 11-11-2007, 06:54 AM
ADMIN AND TECH
its normal to have some oil in the air breather going into the turbo, both valve covers have to come and glow plugs out to run a compression test , have to have theright adaptor to fit where the glow plugs go, doubt its low compression, have you checked codes , is maintenance up, may want to run a fuel pressure test
Old 11-11-2007, 06:10 PM
yes maintenance is good i change oil every 3500 miles i use rotella 15 40 and donaldson oil filter, i change my fuel filter every 7000 mi with baldwin filter air filter as needed, my fuel pressure gauge shows 60 psi at idle it is under the hood so i dont know what it is running down the road
Old 11-12-2007, 03:27 PM
I pulled codes today and had two they are as follows
p1211---injector control press. above/below..
p0475---exhaust pressure control valve malfunction ---i have my ebpv plug unhooked is the code from that?
Old 11-12-2007, 06:33 PM
http://www.powerstroke.org/forum/ima...ilies/bump.gif
Old 11-16-2007, 03:29 PM
run some deisel kleen in it, can get it at any truck stop or wal-mart for about 5 bucks
