7.3 shaking, missfiring, smoking - Ford Powerstroke Diesel Forum
post #1 of 18 Old 01-10-2013, 09:18 PM Thread Starter
HillbillyDeluxe39's Avatar
Went to town this morning, I noticed my engine shaking at the stoplight, kinda like a big block with a big cam. When I left the store to head back home I noticed a sharp rattle that went along with engine RPM, then it began to pour white smoke all the way home.
Ive got AE and it gave me these codes.
P0603
P1212
P1248
P1211
P0541
Injector contribution test only showed #8 as being bad, which I expected.
Im not an expert with AE and thats were I need help, what sensors and what values should I look at in order to determine what has happened.
This is my daily driver so any help is appreciated.
__________________
2000 F250 CCSB 4x4
6637, Tony Wildman Tunes, HPx, Terminator HPOP, 6.0 IC, WW, 285/75R16 Hankook Dynapro AT's
HillbillyDeluxe39 is offline
post #2 of 18 Old 01-10-2013, 10:03 PM
Winning DUHHH
Young-SC-Owner's Avatar
Quoted: 8 Post(s)
Check your uvch's, and drain your fuel bowl, change fuel filter.
Sent from my iPhone using AutoGuide.com App
99.5 F-350 SRW Short Bed, Ex Cab.
6637
Wicked Wheel'd,
Southbend
Autometer - Boost, Pyro
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
7 year Veteran with SBFD
Airframe and Powerplant Mechanic
Head Marine Technician
Dont Tread on Me
Young-SC-Owner is offline
post #3 of 18 Old 01-11-2013, 04:24 AM
This.
carolinaboy02powerstroke is offline
post #4 of 18 Old 01-11-2013, 08:17 AM Thread Starter
Update.
This morning I checked the ICP for oil in the plug, didn't find any.
I poked around the IPR and the "coil" I'm assuming, part that the plug goes into, was loose within the regulators body.
I pushed on the UVCH plug and it seemed to move in about a 1/16 of an inch on both sides.
Used AE did a buzz test on the cold engine, everyone buzzed ok.
Fired right up, no smoke, air temp was around 55*, had a noticeable miss in the exhaust note, and a slightly rough idle.
Warmed up went for a drive, monitored with AE, everything was within parameters.
Never smoked one bit, it did however miss a few times in the 80 horse tow tune.
Stock setting, HPOP hit 2600-3000 psi
Coolant temp sensor was erratic, showing 39* then 270* it was all over the place.
Thoughts...
2000 F250 CCSB 4x4
post #5 of 18 Old 01-11-2013, 08:21 AM
Bad thermostat maybe, in regards to the erratic temps ? I really have no clue.
post #6 of 18 Old 01-11-2013, 08:39 AM
JJFLASH's Avatar
Quoted: 111 Post(s)
There are more than one UVCH plug. Are you familiar with that system?
-JJ-
Mine - 94.5 F250 ZF5: Basics w/a few extras, DIY bumper, steps and exhaust, AFEII, D60, PMF 2.25 RSK, V-codes
Hers - 04 GM 2500 CCSB 4x4: LB7, EFI Live by KW, 2" Lift, MBRP 4" dp back
RIP 15/08/23- 98 GM 1500 ECSB 4x4: 6.5, straight pipe, K+N filter, 495km w/original pump, trans & t-case
JJFLASH is offline
post #7 of 18 Old 01-11-2013, 08:43 AM
What he said. One on each head under the valve covers.
post #8 of 18 Old 01-11-2013, 08:53 AM Thread Starter
I found both of them, where the valve cover meets the head, I pushed them both in just a little, I didn't look under the VC but I'm preparing to do the 50 cent mod today, so well see. The truck acts nothing like it did yesterday so.... As for the temp, research shows that the ECM outputs a floating signal to AE, the sensor is only there for the dash gauge.
Thanks for the help guys.
I find myself wanting the injectors to be bad so I have a reason to replace with some stage 1's...
Good looking truck carolinaboy, I always wanted one that color.
2000 F250 CCSB 4x4
post #9 of 18 Old 01-11-2013, 09:23 AM
Preciate it. It's been a good one and I wouldn't trade it for anything. It's been my daily driver for the last 3 years and it'll be a weekend truck here in about 6 months once I get a company vehicle.
post #10 of 18 Old 01-11-2013, 10:56 AM
Winning DUHHH
Quoted: 8 Post(s)
Update.
Thoughts...
As for your coolant temp sensor, replace it or look at the wiring, sounds like its either bad or wiring has chaffed. It's cheap just replace it. There is connections under the valve covers to check too. Third thing you can do is start the truck and whole it's idling wiggle the uvch plugs and see if something happened. And lastly just for gigs, disconnect your coolant temp sensor and see what your monitor reads. While running like before
6637
Wicked Wheel'd,
Southbend
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
Dont Tread on Me
