Fuel leak drivers side fuel line - Ford Powerstroke Diesel Forum
Old 01-09-2013, 04:34 PM
I have a 99 F250 7.3. On the drivers side towards the front of the head is the connection point for flexible to the rigid fuel line going up the fuel filter. The push to connect joint is leaking. The steel lines look good no rust. I want to know if anyone has the part number for the vition oring that goes in the flexible line. A 130 dollars is a lot to pay for an oring if there is one available. Thanks Frank
Old 01-09-2013, 04:38 PM
i would check dieselorings.com i think they have the orings you are looking for
