Anyone have the same problem ? ford 550 w/ 7.3 work
truck. sick of problem, also fogs blue smoke around 20 -40 mph w/ no power. ? junk ? |
Sure sounds like a Glow Plug Problem. Check the glow plug relay first.
Jim |
The smoke may be another issue
i had the same smoke problem years ago, ended up being my fuel pump was bad.
hard start: had the same problem, batteries were bad. |
My brother had the same problem on his truck wouldn't start then when it did it blew white smoke. It was an easy fix, but I am not sure what he replaced. I am pretty sure the problem part cost under $20. I will ask him when he gets off work today and tell you later. I think it was the glow plug relay though.
My uncles 1997 7.3 started the same all last winter when it was cold he left it run everywhere we went and plugged it in all the time. Had a buddy look at it and all it was was the glow plug relay and it smoked bad too. I think the relay was like 13 bucks so he spend lots more in electricity and diesel he could of bought it 10 times if he would of just went and got it fixed! He thought the glow plugs were bad and procrastinated but check the relay and dig deeper if needed. The smoke issue i am not sure about what year is this truck??
I asked my brother and he said that it was the glowplug relay. It cost about $25 at NAPA. It took about 15 minutes to change.
This is a sticky in the above maintenance section, here it is so you don't have to look for it. Plus if you need a GPR I highly suggest skipping the cheap Napa 109 units and go with a HD Stancor model.
How to check Glow Plug System To check the Glow Plug Relay (GPR) · Be sure the engine is cold, so that the PCM will tell the GPR to turn on. If the engine is hot, you won’t have as much time to check. · Locate the GPR – Its behind the fuel filter on top of the engine, a little bit toward the passenger side of the valley. There may be two relays there. If so, the rear one is the GPR. It will have two fairly large wires (yellow and brown) connected to one of the large posts. · With your multitmeter set to DC volts, and 15 V range (if not autoranging), clip the positive (red) lead to the output terminal (with yellow and brown wires connected), and the negative (black) lead to a good ground point (like the battery ground terminal or someplace metal directly on the engine block.) · Turn the key to ON (do not start) · If your GPR is good, it should click, and you’ll see 11 volts or so on your meter, then, depending on temperature, it will click off up to 2 minutes later. You should do this a couple of times to make sure it consistently makes the connection. · If you don’t get voltage with this test, confirm by retesting as follows. · Remove the two small wires from the smaller two of the four GPR terminals. · With jumper wires, apply voltage from the battery across the two small terminals. If your voltmeter now reads voltage on the output terminal, your GPR is OK, and your problem is in the PCM circuit that tells the GPR to activate. If your GPR is bad you can use the factory replacement for around $75, Napa's GP110 is close to this price maybe $10 cheaper. But you can get a GPR 109 from Napa for around $22.00 This is the same exact relay as the GP110 except the mounting holes are rotated 180 degrees, which is no big deal as the wires stretch just fine. Now if you are tired of replacing your GPR and want a H.D. alternative may I suggest the Stancor 586-902. This is a large relay and it can truly handle the large AMP draw our trucks call for at start up. Gopher Electronics has these for under $40. I know several folks that live way up North (Alaska, Canada) where they know about serious cold starts and they all swear by the Stancor. I am very happy with mine, I believe I have pics of mine installed in my webshots. To check Glow Plugs. · Remove the electrical connector on the inboard side of valve cover at the gasket. Press down on the top of the connector latch and pry gently with a screwdriver. Photo of disconnecting one and another Photo of it loose. · There will be 9 pins on the valve cover gasket where you removed the connector. The two pins furthest forward and the two pins furthest back are for your glow plugs. · With your multimeter set to resistance (ohms) and low range (single digits) if not autoranging, clip the negative (black) lead to a good ground point. · Probe each of the 4 outer pins individually with the positive (red) lead, noting the resistance. Good glow plugs will have a resistance between 0.6 and 2 ohms. If you get infinite resistance on any glow plug, that one is either bad or the connector under the valve cover has come loose. Take Care Kevin |
