Hot Starting Problem - Ford Powerstroke Diesel Forum
Old 01-05-2013, 04:57 PM
I have a 2003 f-250 7.3 - after running and hot I will turn motor off and a few minutes later try to start with no luck . It will restart after about 15-20 minutes
Sitting. It has also quit while going down the highway , only starting after sitting for 15-20 minutes. My mechanics wants to replace the high pressure fuel pump and regulator ($1500). A. New CPS has been installed.
Any thoughts are greatly appreciated.
Old 01-06-2013, 11:23 AM
I am having the same problem after replacing the HPOP. Curious to see what may be wrong.
Old 01-06-2013, 01:00 PM
There is no high pressure fuel pump on these engines. It is a high pressure oil pump(HPOP).
Do you have any codes?
