Normal poppet wear during a HPOP rebuild? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 01-02-2013, 11:02 PM Thread Starter
Background info: I had a fuel gasket blow out, fixed that. Then the fuel pump went out, fixed that. Figured it was the Fuel Pressure Regulator that needed to be cleaned up - took that apart. Decided to redo the fuel bowl o-rings while I was at it.
Noticed that the HPOP was leaking so needed to redo the seals on it. When I was getting ready to re-install the poppet check valve and spring into the HPOP I saw fresh aluminum inside the HPOP, but I am not sure if this is normal wear or not. HELP!
Please see attached pictures.
2003 7.3 PSD, stock, 125k miles.
ID:	48716   Click image for larger version
jvandehe is offline
post #2 of 2 Old 01-03-2013, 09:43 AM Thread Starter
one more picture
This is a zoomed in picture of the 'abnormal' looking wear.
Name:	1-3-2013 10-40-05 AM.jpg
jvandehe is offline
