Power steering flush question - Ford Powerstroke Diesel Forum
Old 12-30-2012, 04:26 PM
I have a 2000 f350. I just did the power steering flush and noticed that when I was cycling the steering wheel the fluid was barely coming out when I hit the brakes you could see the ATF flow through the clear hose. So I guess my question is should the ATF flow out the return line when turning the steering wheel or only when pressing the brakes. Thanks for the help
Old 12-30-2012, 04:38 PM
It does flow while steering but very little, most of the flow is when pressing the brakes but you want to do both to completely flush the system.
Old 12-30-2012, 05:13 PM
Thanks just making sure I didn't have a problem.
