HPOP Squeal
Hello,
I just came back from det and noticed my HPOP is leaking at the rear, drivers side connection. Before the leak was discovered, when I started the engine as the RPM's went from 1500 to 1900 just after the engine start I would hear a squeal coming the HPOP area. I checked my oil level and it was low, put 1.5 gallons in it and then fixed the oil leak but now when I crank the engine I get the same squeal for about 10-15 seconds. Is my HPOP bad? any other ideas?
Thanks for the help.
