Reset the computer / PCM / CPU ? - Ford Powerstroke Diesel Forum
Old 11-01-2007, 08:09 PM
Living on a prayer
On my new-to-me truck so far i've upgraded the air intake (well, slightly, at least) and upgraded exhaust. Also a new tranny. I've heard that giving the computer a reset will help by letting it re-learn the optimal settings. fact or fiction? if fact, how do you do it? unplug one or both batteries? or is there a fuse to simply pull for 15 minutes?
thanks.
Old 11-01-2007, 08:16 PM
thanks.
the PCM/TCM will learn the stratagy over time weather you reset them or not....although they learn them faster if you reset them.
to reset them....disconnect the battery cables with the headlights on, when both are disconnected...put the positive and negative battery cables together (touching) for about 45 minutes then recconect everything (obviously dont connect one battery with the other cables still touching)...that will reset KAM (Keep alive memory)
Old 11-02-2007, 05:16 AM
Living on a prayer
Talking
Thanks Marc. I'd have never guessed it was so complex a process. You're not pulling my leg, are you?
Old 11-02-2007, 05:37 AM
what does doing this help? what are optimal settings its gonna relearn?
Old 11-02-2007, 06:04 AM
Living on a prayer
Mark, any recommendations on anything specific to do after resetting it? i.e. drive under 2K RPM on flat ground.... no load.
Old 11-02-2007, 06:07 AM
it lets the truck learn "your driving habbits"
no....just drive it like your going to drive it normally
Old 11-02-2007, 09:14 AM
Living on a prayer
Marc, what's the significance of each step in this process? the lights on, connecting the battery cables...
