Looking for help again please, Power Loss
I have a 2001 F-350 7.3 powerstroke, and it surfaced an engine light, and loss power. Took it to the local Ford Dealer which heard later might have been mistake, anyway, they told me #2 and #8 injectors bad, Uv harnesses, Valve Covers, IPR sensor and camshaft position sensor around, $2700.00 repair. Finally here is Question-----Can anyone tell me if it is likely that all these things went wrong at the same time? Or is it possibly a we'll just change all this because we are not sure? Or is it like the older, better theory if you replace this need to replace all that, example clutch bad your there replace throw out bearing and pressure plate as well? Last but not lease Do you think I should just, quit whinning about $3000.00 and fix it all broke or not? Thanks for any and all help!!!!!!!!!!
P.S. Last night asked if anyone could give me cylinder order for my 2000 should have been 2001 7.3 powerstroke Does this make difference. Also thanks to all last night for you great help.
