Strong raw fuel smell..... - Ford Powerstroke Diesel Forum
Old 12-28-2012, 11:06 AM
Question Strong raw fuel smell.....
I have a early 1999 F250 PS. With 206000+ miles on it. About two months ago, I started to smell a very strong odor of raw fuel. Started or not started. Does not blow much smoke. I have however noticed that it is using more oil and antifreeze.
What I'm needing to know is, what might be causing this? I have heard everything from, up-pipes, bad injectors. Any help on where to start would be great.
Old 12-31-2012, 02:22 PM
try replacing your fuel seperator valve assembly on the back of the fuel filter.
Old 12-31-2012, 03:56 PM
There are Many places you might have a fuel leak, don't replace anything until you confirm that's what's leaking
Climb up on the motor and look down into the valley with a strong flashlight. Is it "dry" Is there Engine oil or Fuel in there? How about on the back of the pass head where a hardline is clipped to it? Is there fuel leaking from there?
I'm not sure how losing (or burning) oil & coolant could be related to a "strong raw fuel smell". Check for leaks on all 3 though...
Old 12-31-2012, 05:06 PM
Check your coolant tank to see if you have fuel in your coolant. Leaking injector cups will cause the strong fuel smell as well
Old 01-01-2013, 08:38 AM
That's an excellent point!
It could be a common factor in the 3, never thought about the fuel smell "cooking" in the coolant.
Good Call Motomez!
Old 01-01-2013, 10:51 AM
Good Call Motomez!
Thanks Brother, I just had the same problem on my 7.3. I picked up a injector cup kit from Angelofishs on ebay for less than $400.
Happy New Year
Old 01-02-2013, 07:12 AM
Thanks!!!
I will check all those and let you know what I find out.
