maybe fried my pcm? or something else - Ford Powerstroke Diesel Forum
Old 12-13-2012, 05:29 PM
Well I ordered a TS single position chip from xpd, plugged it in did everything as per the instructions. Hooked everything back up and correctly went to turn the key and all the check engine/water in fuel ect lights came on and i go to crank it and it sounds like dead batteries. The cab lights will flash/go dim then brighten back up.
Also tried it with the chip out same effect.
Does anyone have any clue what this could be?
Old 12-13-2012, 07:59 PM
Charge up your batteries and cross your fingers. Did you have the key in the ignition when you installed the chip? If so you probably fried your PCM.
Old 12-13-2012, 08:36 PM
It was the batteries, alternator went bad and they just happened to go out today.
