GEM pin out
Does anyone have a pin diagram for a GEM from a 2000? I am trying to track down a 150ma draw and tracked it down to the top connector in the GEM. It's either the GEM itself using it or something powered off it's 5a circuit but the diagram I have is lacking connector pin outs.
maybe this will help...
SM |
Thank you, that's exactly what I needed.
Slightly closer. Found C240A #9 shift ctrl encoder grd return is causing a .064a draw when connected. Looks like it connects to the GEM C240A, transmission range sensor C1012 and transfer case C285B. Now if I could just figure out why that is making a difference with the key off I will have found half of the battery drain.
replied to your current drain thread.
SM |
You're coming-up with some Great stuff!
![]() Where are you finding all these .pdf's? |
it is best to just be thankful for the info.
SM |
