Cruise Control Not Working. - Ford Powerstroke Diesel Forum
Old 12-03-2012, 02:19 PM
My cruise control isn't working anymore. None of the buttons on the steering wheel do anything. I think I have checked the proper fuses etc.. Can anyone walk me through this?
Old 12-03-2012, 03:18 PM
quite a few possibilities. here is the wiring diagram. definitely gonna require some back probing.
SM
Old 12-09-2012, 04:33 PM
If you have a manual trans check the clutch pedal position sensor--$40 at Napa and it fixed my cruise control issue. If it will start without depressing the clutch to the floor then that is your huckleberry! Good Luck!
Old 12-10-2012, 02:53 PM
Sounds like you probably need a new clockspring. Check fuses first. The clockspring is basically a coil of wires behind your steering wheel in a plastic housing, that run the horn, airbag, and cruise buttons. If you search "clockspring" u should find some good info. Fyi u will need a steering wheel puller.
Sent from my iPhone using AG Free
Old 03-26-2013, 02:43 PM
Maybe that's whats wrong with my cruise control. When i turn to right it makes a clicking noise. How do you go about changing it? Pull the steering wheel off?
Old 03-27-2013, 12:31 PM
airbag light and no horn
