Front Hub/Bearing replacement comparison - Ford Powerstroke Diesel Forum
Old 11-29-2012, 04:39 AM
After getting a nearly 500 dollar front replacement hub from Ford dealership,,, I find this Timken replacement unit for less than 1/2 the price from Ford.
Does anyone have any experience with these Timken replacement bearings? The write ups I saw were positive.
Quite a savings compared to what I paid.!
Timken - Auto Parts Warehouse
Old 11-29-2012, 05:29 AM
Timken is a major player in the automotive world. I would not hesitate to use their products.
SM
Old 11-29-2012, 05:32 AM
I used cheap eBay ones first. I can tell you they're garbage after cooking two in about 6 months. Put in timken from autozone and have about 40k miles on it and its great so far. I even took it apart to look for bluing from heat and there is none.
Also riffraff sells a fitting that allows you to grease them. Worth every penny IMO.
Sent from my iPhone using AutoGuide.com App
Old 11-29-2012, 05:36 AM
I replaced my passenger side with a Timken about a month ago. So far, so good! I deal with their industrial bearings all the time @ work. They are a pretty quality product.
Old 11-29-2012, 05:39 AM
Almostdunfukinwidit
Timken is the only way to go.
Old 11-29-2012, 05:47 AM
well im about to put a skf on mine later today. couldnt find a timken here.
Old 11-29-2012, 05:58 AM
does the picture of the item you linked look remotely like the proper part?
Old 11-29-2012, 06:25 AM
Yep ! exactly like the one I paid the Ford stealership nearly 500 bucks for!
Old 11-29-2012, 06:32 AM
[QUOTE=Schnot;3362267]
Also riffraff sells a fitting that allows you to grease them. Worth every penny IMO. QUOTE]
I have not yet found that fitting on RIffRaff site ? gotta' link to it?
does the fitting allow adding grease to the main non-servicable bearing or the needle bearings?
thanks RB
Old 11-29-2012, 06:36 AM
Riffraff Diesel Performance Parts: - Riffraff Diesel Products
