What could this be? - Ford Powerstroke Diesel Forum
Old 11-28-2012, 03:24 AM
What could this be?
Hard to start,idles okay,perhaps slight miss.Stumbles and eventually stalls after between 1 to 3 minutes.Won't start until left to sit a while.
No ces light.
Codes P0263, P0266, P0269, P0275.
Old 11-28-2012, 09:30 AM
Feedback Score: 5 reviews
By Ken Payne
All Ford vehicles since 1996 feature OBD-II (On Board Diagnostics) capabilities. The vehicle's computer stores diagnostic codes that can be read with a code reader (such as those found on a hand-held performance tuner like the Diablo Predator or Superchips Microtuner. These codes can help you diagnose potential problems with your vehicle. Note that there are a few Ford models featuring the EEC-V processor before 1996 which supported OBD-II codes.
P0102
MAF Circuit Low Input
P0103
MAF Circuit High Input
P0106
BARO Sensor Circuit Performance
P0107
BARO Sensor Low Voltage Detected
P0108
BARO Sensor High Voltage Detected
P0109
BARO Sensor Circuit Intermittent
P0112
IAT Circuit Low Input
P0113
IAT Circuit High Input
P0117
ECT Circuit Low Input
P0118
ECT Circuit High Input
P0121
TP Sensor Circuit Performance Problem
P0122
TP Sensor Circuit Low Input
P0123
TP Sensor Circuit High Input
P0125
Insufficient Coolant Temperature To Enter Closed Loop
P0126
Insufficient Coolant Temperature For Stable Operation
P0
Air Intake Temperature To High
P0131
Upstream HO2S Circuit Out Of Range Low Voltage, Bank No. 1
P0132
Upstream HO2S Circuit Voltage High, Bank No. 1
P0133
Upstream HO2S Circuit Slow Response, Bank No. 1
P0135
Upstream HO2S Heater Circuit Fault, Bank No. 1
P0136
Downstream HO2S Circuit Fault, Bank No. 1
P0138
Downstream HO2S Circuit Voltage High, Bank No. 1
P0140
Downstream HO2S Circuit Faulty, Bank No. 1
P0141
Downstream HO2S Heater Circuit Fault, Bank No. 1
P0151
Upstream HO2S Circuit Out Of Range Low Voltage, Bank No. 2
P0152
Upstream HO2S Circuit Voltage High, Bank No. 2
P0153
Upstream HO2S Circuit Slow Response, Bank No. 2
P0155
Upstream HO2S Circuit Fault, Bank No. 2
P0156
Downstream HO2S Circuit Fault, Bank No. 2
P0158
Downstream HO2S Circuit Voltage High, Bank No. 2
P0160
P0161
Downstream HO2S Heater Circuit Fault, Bank No. 2
P0171
System Too Lean, Bank No. 1
P0172
System Too Rich, Bank No. 1
P0174
System Too Lean, Bank No. 2
P0175
System Too Rich, Bank No. 2
P0176
Flexible Fuel Sensor
P0180
Engine Fuel Temperature Sensor Circuit, Electrical Fault
P0181
P0182
P0183
P0186
Engine Fuel Temperature Sensor B Circuit
P0187
P0188
P0190
Fuel Rail Pressure Sensor Signal Low
P0191
Fuel Rail Pressure Sensor Circuit Performance
P0192
Fuel Rail Pressure Sensor Circuit Low Input
P0193
Fuel Rail Pressure Sensor Circuit High Input
P0201–P0212
Injector Circuits
P0217 P0218
Engine Coolant Overtemp Condition
P0222
Throttle Position Sensor B Circuit Input Low
P0223
Throttle Position Sensor B Circuit Input High
P0230
Fuel Pump Primary Circuit Fault
P0231
Fuel Pump Secondary Circuit Low
P0232
Fuel Pump Secondary Circuit High
P0234
Supercharger Overboost Condition
P0243
Supercharger Bypass Solenoid Malfunction
P0298
Engine Oil Over Temperature Condition
P0300
Random Misfire Detected
P0301–P0310
Misfire Detected Cylinders 1–10
P0320
Ignition Engine Speed Input Circuit Fault
P0325
A Spark Knock Occurred & Sensor Circuitry Did Not Respond
P0326
Spark Knock Has Not Been Sensed
P0330
P0331
P0340
CMP Sensor Circuit Fault
P0350
Ignition Coil Primary Circuit Fault
P0351-P0360
Ignition Coil (A through J) Primary/Secondary Circuit Fault
P0385
Misfire Detection Sensor Circuit Failure
P0400
EGR Flow Faulty
P0401
Insufficient EGR Flow
P0402
EGR Flow Excessive At Idle
P0411
Secondary Air Injection System Flow Improper
P0412
Secondary Air Injection System Control Valve Faulty
P0413
Secondary Air Injection Solenoid Did Not Change When Activated
P0414
P0416
P0417
P0420
Catalyst System Efficiency Below Limit, Bank No. 1
P0421
P0430
Catalyst System Efficiency Below Limit, Bank No. 2
P0431
P0440
Evaporative Emission Purge Control Solenoid Damaged
P0442
Leak In Evaporative System Detected
P0443
EVAP Canister Purge Control Solenoid Or Valve Faulty
P0446
Evaporative Emission Control System Vent Control Malfunction
P0451
Fuel Tank Pressure Circuit Noisy
P0452
Fuel Tank Pressure Signal Circuit Input Below Minimum
P0453
Fuel Tank Pressure Signal Circuit Input Above Maximum
P0455
Leak Or Blockage Detected In Evaporative Emission Control System
P0456
Very Small Leak Detected in Evaporative Emission Control System
P0457
Fuel Filler Cap Loose Or Off
P0460
Fuel Level Sensor Input Circuit Malfunction
P0500
Vehicle Speed Sensor Fault
P0501
Vehicle Speed Sensor Range/Performance
P0503
VSS Intermittent
P0505
Idle Air Control Valve System Fault
P0552
Power Steering Pressure Sensor Shorted To Power
P0553
P0602
Control Module Programming Error
P0603
PCM KAM Test Error
P0605
PCM Read Only Memory Error
P0703
Brake On/Off Switch Input Fault
P0704
Clutch Pedal Position Switch Input Circuit Fault
P0705
Transmission Range Sensor Out Of Self Test Range Or Shorted To Ground
P0707
Transmission Range Sensor Circuit Low Input
P0708
Transmission Range Sensor Circuit High Input
P0712
Transmission Fluid Temperature Sensor Circuit Input Low
P0713
Transmission Fluid Temperature Sensor Circuit Input High
P0715
turbine Shaft Speed Sensor Circuit Fault
P0717
Transmission Concern
P0720
Output Shaft Speed Sensor Circuit
P0721
P0722
No Signal From Output Shaft Speed Sensor
P0723
Output Shaft Speed Sensor Circuit Intermittent Failure
P0731
Improper Ratio For First Gear
P0732
Improper Ratio For Second Gear
P0733
Improper Ratio For Third Gear
P0734
Improper Ratio For Fourth Gear
P0735
P0736
Improper Ratio For Reverse Gear
P0741
TCC System Improper Mechanical Performance
P0743
Torque Converter Clutch System Electrical Failure
P0746
Electronic Pressure Control Solenoid Performance
P0750
Shift Solenoid No. 1 Circuit
P0751
Shift Solenoid No. 1 Performance
P0755
Shift Solenoid No. 2 Circuit
P0756
Shift Solenoid No. 2 Performance
P0760
Shift Solenoid No. 3 Circuit
P0761
Shift Solenoid No. 3 Performance
P0765
P0781
1 To 2 Shift Error
P0782
2 To 3 Shift Error
P0783
3 To 4 Shift Error
P0784
4 To 5 Shift Error
P0796
P0797
P0799
P0812
Reverse Switch Input Circuit Malfunction
P0813
P0815
P1000
OBD II Monitor Testing Incomplete
P1001
KOER Test Cannot Be Completed
P1039
Vehicle Speed Signal Missing Or Improper
P1051
Brake Switch Signal Missing Or Improper
P1100
Mass Air Flow Sensor Intermittent
P1101
Mass Air Flow Sensor Out Of Self Test Range
P1109
IAT Sensor 2 Intermittent
P1112
IAT Sensor Intermittent
P1114
IAT Sensor 2 Circuit Low Input
P1115
IAT Sensor 2 Circuit High Input
P1116
ECT Sensor Out Of Self Test Range
P1117
ECT Sensor Intermittent
P1120
TP Sensor Out Of Range Too Low
P1121
TP Sensor Inconsistent With MAF Sensor
P1124
TP Sensor Out Of Self Test Range
P1125
TP Sensor Intermittent
P1
HO2S Heater Not On During KOER Test
P1128
HO2S Sensor Signals Swapped
P1129
P1130
Lack Of Upstream HO2S Switch, Adaptive Fuel Limit, Bank No. 1
P1131
Lack Of Upstream HO2S Switch, Sensor Indicates Lean, Bank No. 1
P1132
Lack Of Upstream HO2S Switch, Sensor Indicates Rich, Bank No. 1
P1135
Ignition Switch Signal Missing Or Improper
P1137
Lack Of Downstream HO2S Switch, Sensor Indicates Lean, Bank No. 1
P1138
Lack Of Downstream HO2S Switch, Sensor Indicates Rich, Bank No. 1
P1150
Lack Of Upstream HO2S Switch, Adaptive Fuel Limit, Bank No. 2
P1151
Lack Of Upstream HO2S Switch, Sensor Indicates Lean, Bank No. 2
P1152
Lack Of Upstream HO2S Switch, Sensor Indicates Rich, Bank No. 2
P1157
Lack Of Downstream HO2S Switch, Sensor Indicates Lean, Bank No. 2
P1158
Lack Of Downstream HO2S Switch, Sensor Indicates Rich, Bank No. 2
P1168
Fuel Rail Pressure Sensor In Range But Low
P1169
Fuel Rail Pressure Sensor In Range But High
P1180
Fuel Delivery System Low
P1181
Fuel Delivery System High
P1183
Engine Oil Temperature Sensor Circuit Malfunction
P1184
Engine Oil Temperature Sensor Out Of Self-Test Range
P1220
Series Throttle Control Fault
P1224
Throttle Position Sensor B Out Of Self Test Range
P1229
Supercharger Intercooler Pump Not Operating
P1230
Open Power To Fuel Pump Circuit
P1231
High Speed Fuel Pump Relay Activated
P1232
Low Speed Fuel Pump Primary Circuit Failure
P1233
Fuel Pump Driver Module Off Line
P1234
P1235
Fuel Pump Control Out Of Range
P1236
P1237
Fuel Pump Secondary Circuit Fault
P1238
P1244
Alternator Load Input Low
P1245
Alternator Load Input High
P1246
Alternator Load Input Problem
P1250
Lack Of Power To FPRC Solenoid
P1260
THEFT Detected, Engine Disabled
P0
Engine RPM Or Vehicle Speed Limiter Reached
P1285
Cylinder Head Over Temperature Sensed
P1288
Cylinder Head Temperature Sensor Out Of Self Test Range
P1289
Cylinder Head Temperature Sensor Signal Greater Than Self Test Range
P1290
Cylinder Head Temperature Sensor Signal Less Than Self Test Range
P1299
Cylinder Head Temperature Sensor Detected Engine Overheating Condition
P1309
Misfire Detection Monitor Not Enabled
P1351
Ignition Diagnostic Monitor Circuit Input Fault
P1352
Ignition Coil A Primary Circuit Fault
P1353
Ignition Coil B Primary Circuit Fault
P1354
Ignition Coil C Primary Circuit Fault
P1355
Ignition Coil D Primary Circuit Fault
P1356
Loss of Ignition Diagnostic Module Input To PCM
P1358
Ignition Diagnostic Monitor Signal Out Of Self Test Range
P1359
Spark Output Circuit Fault
P1364
P1380
Variable Cam Timing Solenoid Valve Circuit Short Or Open
P1381
Variable Cam Timing Advance Excessive
P1383
P1390
Octane Adjust Out Of Self Test Range
P1400
Differential Pressure Feedback Electronic Sensor Circuit Low Voltage
P1401
Differential Pressure Feedback Electronic Sensor Circuit High Voltage
P1403
Differential Pressure Feedback Electronic Sensor Hoses Reversed
P1405
Differential Pressure Feedback Electronic Sensor Circuit Upstream Hose
P1406
Differential Pressure Feedback Electronic Sensor Circuit Downstream Hose
P1407
EGR No Flow Detected
P1408
EGR Flow Out Of Self Test Range
P1409
EGR Vacuum Regulator Circuit Malfunction
P1410
EGR Barometric Pressure Sensor VREF Voltage
P1411
Secondary Air Is Not Being Diverted
P1413
Secondary Air Injection System Monitor Circuit Low Voltage
P1414
Secondary Air Injection System Monitor Circuit High Voltage
P1442
P1443
Evaporative Emission Control System, Vacuum System, Purge Control Solenoid Or Purge Control Valve Fault
P1444
Purge Flow Sensor Circuit Input Low
P1445
Purge Flow Sensor Circuit Input High
P1450
Inability Of Evaporative Emission Control System To Bleed Fuel Tank
P1451
Lack Of Response From Passive Anti-Theft System Module, Engine Disabled
P1452
P1455
Substantial Leak Or Blockage In Evaporative Emission Control System
P1460
Wide Open Throttle Air Conditioning Cutoff Circuit Malfunction
P1461
Air Conditioning Pressure Sensor Circuit Low Input
P1462
Air Conditioning Pressure Sensor Circuit high Input
P1463
Air Conditioning Pressure Sensor Insufficient Pressure Change
P1464
A/C Demand Out Of Self Test Range
P1469
Low A/C Cycling Period
P1473
Fan Secondary High With Fans Off
P1474
Low Fan Control Primary Circuit
Hydraulic Cooling Fan Primary Circuit Failure
P1477
Medium Fan Control Primary Function Failure
P1479
High Fan Control Primary Circuit
P1480
Fan Secondary Low With Low Fans On
P1481
Fan Secondary Low With High Fans On
P1483
Power To Cooling Fan Exceeded Normal Draw
P1484
Variable Load Control Module Pin 1 Open
P1500
Vehicle Speed Sensor Intermittent
P1501
VSS Out Of Self-Test Range
P1502
Invalid Or Missing Vehicle Speed Message Or Brake Data (1998)
VSS Intermittent (1999)
P1504
IAC Circuit Malfunction
P1505
IAC System At Adaptive Clip
P1506
IAC Over Speed Error
P1507
IAC Under Speed Error
P1512
Intake Manifold Runner Control Stuck Closed
P1513
P1516
Intake Manifold Runner Control Input Error
P1517
P1518
Intake Manifold Runner Control Fault, Stuck Open
P1519
Intake Manifold Runner Control Stuck Open
P1520
Intake Manifold Runner Control Circuit Fault
P1530
Open Or Short To A/C Compressor Clutch Circuit
P1537
P1538
P1539
Power To A/C Compressor Clutch Circuit Exceeded Normal Current Draw
P1549
IMT Valve Vacuum Actuator Connection (1996-98)
Intake Manifold Communications Control Circuit Malfunction (1999)
P1550
Power Steering Pressure Sensor Out Of Self Test Range
P1565
Speed Control System Concern
P1566
P1567
P1568
P1572
Brake Pedal Switch Circuit
P1605
PCM Keep Alive Memory Test Error
P1625
Voltage To Vehicle Load Control Module Fan Circuit Not Detected
P1626
Voltage To Vehicle Load Control Module Circuit Not Detected
P1633
Keep Alive Memory Power Voltage Low
P1635
Tire/Axle Ratio Out Of Acceptable Range
P1639
Vehicle ID Block Not Programmed Or Is Corrupt
P1640
Powertrain DTCs Available In Another Module
P1641
Fuel Pump Driver Module Concern
P1650
Power Steering Pressure Switch Out Of Self Test Range
P1651
Power Steering Pressure Switch Input Fault
P1700
P1701
Reverse Engagement Error
P1702
P1703
Brake On/Off Switch Out Of Self Test Range
P1704
P1705
Manual Lever Position Sensor Out Of Self Test Range
P1709
Park Or Neutral Position Switch Out Of Self Test Range
P1710
P1711
Transmission Fluid Temperature Sensor Out Of Self Test Range
P1713–P1728
P1729
4x4 Low Switch Error
P1740
P1741
Torque Converter Clutch Control Error
P1742
Torque Converter Clutch Solenoid Faulty
P1743
P1744
Torque Converter Clutch System Stuck In Off Position
P1745
P1746
Electronic Pressure Control Solenoid, Open Circuit
P1747
Electronic Pressure Control Solenoid, Short Circuit
P1749
Electronic Pressure Control Solenoid Failed Low
P1751
P1754
Coast Clutch Solenoid Circuit Malfunction
P1756
P1760
P1761
P1762
P1767
P1780
Transmission Control Switch Circuit Out Of Self Test Range
P1781
4x4 Low Switch Out Of Self Test Range
P1783
Transmission Over Temperature Condition
P1784–P1789
P1900
P1901
U1020
Module Communications Network Concern
SCP Invalid Or Missing Data For A/C Compressor Clutch (1998-99)
U1021, U1073 & U1131
Failure In Communication Between PCM & Variable Load Control Module (1994-97)
U1039
SCP Invalid Or Missing Data For Vehicle Speed (1998-2001)
U1039, U1051, U1135 & U1451
Module Communications Network Concern (1994-97)
U1041
U1051
SCP Invalid Or Missing Data For Brakes (1998-2001)
U1131
SCP Invalid Or Missing Data For Fuel System (1998-2001)
U1147
SCP Invalid Or Missing Data For Vehicle Security (1998-99)
U1256
Variable Load Control Module Concern
U1262
SCP Communications Bus Fault
U1451
SCP Invalid Or Missing Data For Anti-Theft Module (1998-2001)
U1850
Invalid Or Missing Fuel system Data
U2243
SCP Invalid Or Missing Data For Exterior Environment (1998-2001)
UXXXX
PCM Concern (1994-97)
U DTCs Received During Self-Test Of Another Module (1998-2001)
Old 11-28-2012, 09:32 AM
7.3 4 Ever! Nothing else!
Feedback Score: 7 reviews
can you email that to me
dgarlock@autofair.com
Old 11-28-2012, 10:16 AM
Done.........................
Old 11-28-2012, 11:08 AM
That didn't help at all.Am i missing something? I understand the codes i have relate to injectors.Is there anything else that could cause this?
Old 11-28-2012, 11:16 AM
No ces light.
cylinder 1 2 3 5 contribution fault
Old 11-28-2012, 11:23 AM
Is there anything that can cause contribution faults other than injectors?
HPOP pressure is 500 or above at idle,rises when stumbling.
Fuel pressure constant at 60psi measured at rear of bowl.
Has new UVCH's,IPC.
Old 11-28-2012, 11:29 AM
ICP scensor leaking oil?
Old 11-28-2012, 11:33 AM
ICP is new.
We did remove and reinstall 2 injectors,1 and 3.Copper washer was reinstalled.Can you stuff up putting them back in anyway?
Old 11-28-2012, 11:37 AM
it could throw a code, even if the ICP scensor is new, if it is leaking at all it will not run right, which would need to be replaced again!
