7.3 won't start - Ford Powerstroke Diesel Forum
post #1 of 9 Old 11-10-2012, 06:49 AM Thread Starter
7.3 won't start
Hello to all, I have a 7.3 I believe it is an 03 in an F350 super duty dually. We use it on our work site and yesterday it would not start. The WTS works and it seems we are getting fuel. Because we were in a hurry yesterday I disconnected the glow plug and gave it a shot of ether it still would not fire at all. I tried a little fuel in the intake and still nothing it just cranks and has no indication of firing at all. Thanks for any help and God Bless!!!!
Vetteran13 is offline
post #2 of 9 Old 11-10-2012, 06:54 AM
Stupidity pisses me off
sevenmalards's Avatar
Quoted: 9 Post(s)
Cam position sensor perhaps
2006 F350 CREW CAB LONG BED KING RANCH
99.5 F350 Super Cab Long Bed, Dually.
SOLD
Originally Posted by SMKSTAX View Post
You are not right man, but i still think your funny as hell!
sevenmalards is offline
post #3 of 9 Old 11-10-2012, 06:55 AM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
Empty the ffuel bowl and then cycle the key to see if it fills up. If it does I'd say cps too
Sent from my SCH-R530U using AutoGuide App
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #4 of 9 Old 11-10-2012, 06:57 AM
Quoted: 9 Post(s)
It could be the injector control pressure module also. With the Cam Position Sensor, It should start, but mine would stall out. I've also experienced the injector control pressure module, that caused it to not start at all. Its an easy replacement.
SOLD
post #5 of 9 Old 11-10-2012, 07:19 AM Thread Starter
How do I check the CPS and the injector module????
post #6 of 9 Old 11-12-2012, 06:11 PM Thread Starter
UPDATE
Ok, I was wrong about the year but I don't think it matters the truck is a 2001. I replaced the cam sensor today and it still will not start. I cannot get the engine to even try to start with ether through the air filter lid, but I did get it to almost chug to life by shooting a little through the glow plug hole. I am going to try to hook up a tester tomorrow and a friend also mentioned a sensor in the cyl head by the drivers side valve cover he said it was for low or restricted oil pressure. Please give me any info you can it will be much appreciated and again God Bless
post #7 of 9 Old 11-17-2012, 04:48 AM
Doesn't Even Care
Quoted: 69 Post(s)
Might wanna do a compression check....
Nick
"The Mistress"
post #8 of 9 Old 11-17-2012, 12:39 PM
Check for air bubbles on dip stick.
Trey7.3 is offline
post #9 of 9 Old 11-26-2012, 06:43 PM
Quoted: 9 Post(s)
That is the injector control pressure sensor.
Did you figure it out?
SOLD
