Please help - Ford Powerstroke Diesel Forum
Old 11-02-2012, 10:25 AM
Please help
I have a 2001 7.3 and urlyer I drove across town to eat it ran perfict. when I started it after eating it started just fine but none of the stuff like oil pressure, fuel,speed, and rpm gauges did not work and i had no throttle.
Old 11-02-2012, 10:44 AM
O and also in the past month it has ran rough at times like it was running out of fuel or there was was air in the lines
Old 11-02-2012, 08:04 PM
IDENTICAL to my buddy's truck. Its a fuse that popped underthe dash, and the reason was the yellow wire being shafed, in the steering column, coming from the shifter lever.
Old 11-02-2012, 08:05 PM
Welcome to guzzle's In-tank Hutch Mod Web Page
Old 11-02-2012, 08:21 PM
Well put a new fuse in but now the fuse blows everytime I drive so I put a bigger amp and it held a little longer but it also blowed
Old 11-02-2012, 08:28 PM
theres a reason, FORD rated each fuse spot. Puting in a higher amp fuse, will result in more catastrophic failure...wires melting, fire...
Remove the "shell" to the shifter column, and inspect the wires, especially the yellow one.
