Bad Hub causing ABS light? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 10-31-2012, 05:30 PM Thread Starter
2001 Excursion PSD. Can a bad front hub cause my ABS light to stay on? Already replaced the rear sensor and checked both front connections. Bad grinding sound now coming from front left. Pretty sure the hub/bearing is shot. Could this produce a ABS light?
Thanks
Bubbalarge
Bubbalarge is offline
post #2 of 2 Old 10-31-2012, 05:32 PM
jesilvas's Avatar
Quoted: 3 Post(s)
Yea. I had a bearing seize up and spin in the race in the hub. Mine would tick while spinning. Anyway, it allows play on the spindle and will damage the ABS sensor in the process.
4R100, 2wd
330,000 + miles
jesilvas is offline
