#30 Fuse 30amp - Ford Powerstroke Diesel Forum
Old 10-28-2012, 12:36 PM
#30 Fuse 30amp
So I did all the research behind the #30 fuse blowing and it leads to the fuel bowl heater. Unplugged it, replace fuse, turn key and sure enough instant blown fuse again.
Any other ideas beside just tracing the wires to see if there is a short??
Thanks,
Drew
Old 10-28-2012, 12:41 PM
Are you sure you unplugged the right thing?
How about tracing back the wiring to the heater and looking for a problem?
Old 10-28-2012, 12:50 PM
Positive it's the correct one unplugged.
Old 10-28-2012, 05:48 PM
Mine did this, it was the harness rubbed through on the drivers side valve cover... Hope this helps
Old 10-28-2012, 10:08 PM
Location: Quit Iraq, got a house in Tooele, Ut, Back in a big wrecker playing in traffic!
Pull the fuse, run a couple wires with spade connectors to the fuse, then through a 12v bulb. the bulb provides enough resistance to keep the fuse from blowing. start wiggling wires, when you get to where the short is the bulb will change brightness or go out, depending on what is still powered in the circuit.
Old 11-03-2012, 12:44 PM
Rubbing on valve cover. Fixed that and no more blown fuses but she won't kick over.
Thought I had it fixed and shed fire right up.
