Rough Idle - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-25-2012, 08:39 AM Thread Starter
Rough Idle
Ok, so last night I went to go home and my 99 PSD started to run weird. The accelerator seemed touchy and it started to Idle very rough, but it lacked no power when I stepped on it. I went home and replaced the CPS and to day I took my kid to school and it idled even rougher. I got to his school and shut it off and started it back up and it seemed to idle fine, but prior to shutting down it did throw a 1280 code. Help I'm at a loss
A1sniper is offline
post #2 of 4 Old 10-25-2012, 09:10 AM
timmyboy76's Avatar
check oil level. remove the plug on the ICP, see if its wet/oil in plug...
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 4 Old 10-25-2012, 09:26 AM
I would start with the ICP sensor as well... Check to make sure the valve cover hanresses are all tight as well.
Jacob@DP-Tuner is offline
post #4 of 4 Old 11-26-2012, 09:49 AM
I am a newbee and my 7.3 idles rough sometimes, just started about a week ago. What is the ICP?
beaux-ex is offline
