99F350 Nostart - Ford Powerstroke Diesel Forum
Old 09-24-2012, 07:43 AM
99F350 Nostart
I am having some issues with my 99 F350. It came to me used, with two bad batteries. I replaced both of them, and have had few issues until recently. The batteries were not being charged it seems, and I swapped out the alternator, as it was only showing 6v when I checked it.
I am now having the same issue. However, the new alternator is only showing .6v or so at idle, when the other showed 6v. Is there a better way to check to see if the alternator is not functioning correctly?
Where else should I start looking? The terminals are clean, and the batteries charge up just fine on a trickle charger, so I dont suspect the connectors right now.
One thing I did notice, is that the boost solenoid was clicking very quickly when I was having starting problems. I suspect low battery power is the issue here, but I am open to checking other avenues.
Any advice here?
Thanks.
Old 09-26-2012, 10:56 AM
Just replaced CPS, and no change in starting. I am going to check the bowl for fuel next, and all the fuses. I assume I am getting fuel, as I can hear the fuel pump running.
Old 09-29-2012, 12:17 PM
Checked HPOP, it was pretty empty. Put probably a quart of oil in there. No change. I disconnected the ICP, and it seemed like it tried, so I may replace that, unless there is a reason not to. All fuses look good, there is fuel in the bowl. I broke the negative terminal on the starting battery after trying to clean it, and open it a bit more. So that is going to be replaced as well.
EDIT: Found out the truck should run with out the ICP even plugged in, so that is likely not the problem. Time to try other things.
Old 09-30-2012, 09:30 PM
Found out the Glow Plug relay was shot. Replaced it, and the truck started right up.
