7.3 no power hauling - Ford Powerstroke Diesel Forum
post #1 of 13 Old 09-09-2012, 12:37 AM Thread Starter
BDB
I have a 2001 7.3 and up until a couple of weeks agao truck would pull just fine. Now when I hook to our 20' gooseneck with the asphlt paver on it roughly 15,000 pounds the truck will barely puul out of its place. once i finally get going my tranny temp goes sky high everything else is fine. Just rebuilt the turbo, all intercooler boots are ok, replace accumalator body in trans and im going to replace the icp sensor and harness on monday because mine is caked with oil. Ive read on other post maybe bad torque converter or cracked flywheel but im clueless and i really need this truck. Any help will be much appreciated!!!!!!!!!!!!
BDB is offline
post #2 of 13 Old 09-09-2012, 05:59 AM
jesilvas's Avatar
Quoted: 2 Post(s)
Did it happen after you did the turbo?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 13 Old 09-09-2012, 06:34 AM Thread Starter
BDB
The squealing quit before rebuild and could tell something was funny, and tranny temp was getting hotter than normal.
BDB is offline
post #4 of 13 Old 09-09-2012, 07:25 AM
timmyboy76's Avatar
With a cracked flywheel, you'd hear it at idle. Sounds like marbles in a can. The noise goes away with a slight hit of the pedal.
I think your on to something though, with the TQ. Could be, its not locking.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #5 of 13 Old 09-09-2012, 10:49 AM
jesilvas's Avatar
Quoted: 2 Post(s)
TC not locking will cause a high temp while running. You'll notice the TC unlocked versus locked.
TC doesn't lock when taking off though.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #6 of 13 Old 09-09-2012, 03:41 PM Thread Starter
BDB
I was thinking maybe the TQ was slipping
More that it was supposed to. I'm not sure. My edge CS has the monitor and it shows when TQ is locked up or not and seems normal but it could just be saying it is but that is in 3rd and 4th gear. But now power at all when pulling a trailer wether in take off or running 50.
BDB is offline
post #7 of 13 Old 09-09-2012, 03:43 PM
jesilvas's Avatar
Quoted: 2 Post(s)
What are your boost numbers?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #8 of 13 Old 09-09-2012, 05:41 PM Thread Starter
BDB
I run my programmer on tow setting and at WOT unloaded about 16-17 psi
BDB is offline
post #9 of 13 Old 09-09-2012, 05:41 PM Thread Starter
BDB
Truck runs fine unloaded just a little sluggish on the take off.
BDB is offline
post #10 of 13 Old 09-10-2012, 05:48 AM
timmyboy76's Avatar
think, you need to get the truck "read". Yoiu/know anybody with a reader, to read these trucks. I'm a rookie at this point, but i think you'll want to know the ICP and duty cycles, C.C.T. test, maybe throw in a buzz test while your at it.
