Rear Axle seal replacement - Ford Powerstroke Diesel Forum
Old 10-17-2007, 03:22 PM
Has anyone removed all of the rear hub on a 2000 250 to replace the inner axle seal? I can't get the hub and have removed all of the bolts that I can see. Thanks for any help.
Old 10-17-2007, 03:44 PM
Not sure, had a buddy that had to do it, but I don't know. I'll bump it for ya
Old 10-18-2007, 08:53 AM
i'm not sure if it is the same but i just did mine on my 95.
first pull the axle and brake drum, then you need the special hub socket, i got mine at the local parts store, undo the hub nut, then it just takes a little effort to pull the hub off, they kind of have a tendancy to stick. but if the hub nut is off it should move around on the housing stub a little.
hope that helps.
Old 10-18-2007, 09:35 AM
Thats Mr. Oil Leak.....
to sam cept for the drum. you have to remove the caliper and caliper bracket to remove the hub/rotor.
