EGT Exhaust help! - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-17-2007, 07:49 AM Thread Starter
bryceba's Avatar
EGT Exhaust help!
Last night I installed a 5 inch exhaust in place of the stock one. The reason why is my egts ran pretty high before. I have an edge evolution, a afe stage 2 intake and now the 5 inch exhaust. The problem I have is that my egts rise higher faster now with the new exhaust. This is the exact opposite of what is normal. My pyrometers thermocouple was not mounted anywhere on the exhaust. I have no idea where it is because I just bought the truck. It is an ISSPRO guage. Could I have a serious issue that is causing such high egts? Or could my guage be bad and the thermocouple located in an innaccurate place. My friend has a 5 inch on the exact same truck and even towing his never goes above 1000 degrees. We have the same mods so thats why I am worried about my truck. Please help if you have any insight or if you need more info
bryceba is offline
post #2 of 4 Old 10-29-2007, 12:16 PM
Powerstroke Junkie
NCHornet's Avatar
Something ain't right. With the mods you have EGT's shouldn't be a problem, especially when not towing. You didn't say what your EGT's are so I will assume we atre talking at or near the redline (caution line) of 1250 degrees. You need to follow some wires and look at the exhaust manifold and find out where the thermocoupler is located. Usually when one goes bad the readings will bounce or not read at all. The end of your thermocoupler could be to close or is touching the wall of the manifold instead of being right in the middle of the manifold. You need to start doing some detective work because with your intake and exhaust EGT's shouldn't be a problem.
Good Luck
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #3 of 4 Old 10-29-2007, 12:22 PM
International Threat
Marty's Avatar
Where are you located? City/State?
2001 F250
11.62 @ 115.79
Owner of Marty's Diesel
Elkton, Maryland
Marty is offline
post #4 of 4 Old 10-29-2007, 02:50 PM
Albie30's Avatar
Send a message via AIM to Albie30 Send a message via Yahoo to Albie30
Check the the eyelet on the wastegate to be sure the clip did not fall out and it is still opening the exhaust valve
2000 F250 cc 4x4 4" lift BFG 315's,,dp tuner Auto Meter gauges, Hybrid 235cc injectors,TN BB turbo,water meth injection,Ragin intake,ITP boost fooler Banks intercooler,big head wastegate,power elbow,torque converter,6.0 tranny cooler,High flow intakes AIH delete air ride air bags,gibson 4" exhaust,zoodad mod, remote start, Pioneer dvd/ navigation Sirrus radio,sun coast tranny ,Bts valve body,H11 s,Engine rebuild .030 over,Fluid Dampner,203 thermostat
425hp 775 Tq
13.9 @ 95 mph
Albie30 is offline
