Backwards but not foreward??? - Ford Powerstroke Diesel Forum
Old 08-04-2012, 01:56 PM
I have an 02 7.3 and just did a few mods. I put in gauges, temp boost and exhaust, new 4" turbo back, wicked wheel, pedestal with EBV delete, waste gate controller and a thermostat. I did everything but gauges and the truck drove fine. When I did the gauges I also ha to do a water pump. My up pipe to turbo was leaking by some so I got that fixed almost (it still is not 100%). When I try to drive the truck reverse works great, I here my turbo whistle, but when I go to drive, nothing. I barely roll foreward. ??????? Any ideas or info is appreciated. Also I have no boost pressure. Do not know if it is gauge or hose messed up. I did the dodge drain plug delete in my heater, and put the turbo sensors hose right above that.
Thanks again
Old 08-04-2012, 02:20 PM
Would the TM controller (if not set up perfect) cause this? It seems like I have no boost at all. Also the directions said crank it in to 2" for a starting point. I went in a lil more, but still no luck....
